Question about Hitachi Audio Players & Recorders
Require a new drive belt for Hitachi D270 cassette tape deck
    Top Expert:
  • Hitachi Master
  • 63,373 Answers
Check with Hitachi . we do not have parts
Posted on Jan 31, 2018
SOURCE:
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
robotek
  • 1512 Answers
SOURCE: JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
  • 4 Answers
SOURCE: Nakamichi BX-2 Cassette Deck Takeup Reel
I had sorta the same problem and I just fixed it. Mine was making clicking noises and jerking the tape causing speed variations and pitch changes, Uggghh. The FF, Rew, and take up functions are not belt driven like most decks. There is a little idler wheel between the motor and the take up axle. Take the whole transport assembly loose from the front of the deck...slide it back 3 inches . Take off the ground wire screw, and 3 screws holding the transport mechanism in place :...1 screw on top, 2 on bottom. Take the black front faceplate off of the drive...2 little screws. This exposes everything.The little idler wheel has a press on tiny,tiny piece of clear plastic holding it onto its little axle. Be hella careful. Use a tiny eyeglass screwdriver to pry it up and off. Dont lose it. Pull the idler wheel off. The rubber has hardened and slips. Pry the rubber rim off of the white plastic pulley using the tiny screwdriver. Put on an O ring that just fits. Scruff up the perimeter of the O ring with 220 sandpaper, Easy does it. Idler wheel goes back in, press on the little plastic retainer, put the black metal plate back on( 2 screws at top), slide the transport mechanism back into the front panel, secure with 3 screws, ground strap, replace cover. Clean heads, demagnetise, badda bing, badda boom.
Posted on Aug 31, 2009
  • 5 Answers
SOURCE: Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
i have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
Who sells replacement drive belts for my ac/dc ge cassette recorder model 3-5025a
Belts for any deck can be obtained from Marrs Communications in TX but if you now the size and width they can also be had cheaper from Consolidated Electronics in OH.
Feb 15, 2015 | Audio Players & Recorders
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
Wheels on the tape deck don't turn on either side, forward or reverse on Sony dual cassette tape deck
You have a broken transfer belt and it needs replacement.
This will require you to take the tape deck apart to service it.
Mar 24, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Top Hitachi Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Carlos Oliveira
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
