Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Right hydro gear moans and fails to work after 30-40 minutes
I have a 50" Cub Cadet zero turn mower that works fine for approximately 30-40 minutes and then the right hydro gear begins to moan and turning to the left becomes increasingly difficult until finally it becomes impossible to turn to the left. After the mower is allowed to cool for 15-20 minutes operation is normal again for a short period of time at which the process repeats itself. The certified dealer has only been instructed by Cub Cadet to replace the valve body twice. The problem still persists.
  • 3 more comments
  • ZeroTurn Jul 30, 2009
    Why would this only happen after 30-40 minutes and not happen all the time?
    I would lean more to the hydraulic pressure loss than the control lever. The lever moves the same distance in the beginning as it does 30-40 minutes later. What would cause the pressure loss?
    Thanks for the help. Any suggestions on how to persuade Cub Cadet to replace the pump. They have instructed the authorized mechanic to replace the valve body twice, but the problem continues. It's like they know that there is a problem with the pump but do not want to replace it.
  • ZeroTurn Jul 31, 2009
    Thanks for the help. I will suggest this. After all, replacing the valve body has already been tried twice. The mechanic was able to replicate the problem. After opening up the gear, he replied that he was unable to detect anything. Maybe this time Cub Cadet will see that their solution is not solving the problem. Again, thank you for the advice.
    Yes. This solution was helpful. I only hope that we can persuade the Cub Cadet representative to replace the gear.
  • 19,396 Answers
I think that you have a have a hydro pump failing in athe two-pump system. The pump may fail after some time because some debris that passed the filter and entered into the pump is jamming the pump after some time.
Since the pump is expensive, it is worth having it checked by a mechanic while the problem occurs. If a single pump fails on its own and there is no electrical problem, then the pump must be replaced or rebuilt.
Posted on Jul 30, 2009
  • Ginko
    Ginko Jul 30, 2009
    they do not want to replace because the pump is a couple of thousands. Insist with the mechanic to test the tractor when the problem happens, if the mechanics rule out any other cause and the valve body had already been replaced they should go for the pump, even if the pump failing after a while suggests to replace the valve body.
    President:
  • 1,714 Answers
When you move a steering/speed lever, you are controlling the
flow of fluid through the transmission and the rotational speed or the forward/reverse direction of a
drive wheel. Maximum lever movement means maximum fluid flow, which translates into a rapidly
turning wheel.
I think the control from the lever is causing your problem.
  • 1 more comment
  • Craig Butler
    Craig Butler Jul 30, 2009
    If it's not the control lever issue then I would go straight to the wheel motor.
  • Craig Butler
    It probably begins to loose hydraulic pressure as it runs, slowly loosing pressure and flow.
  • Marcus Peacock Jun 12, 2013
    Ok, but how do you fix this issue? costly?
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
On my 2007 cub cadet zero turn my right wheel will stop working
This does not sound good if its still under warranty get it back there asap... sounds like a lazy drive weather its juat a faulty drive or your hydro pump not feeding that side, it should not be unservicable after 90hrs... even if its out of warranty get it fixed asap as the metal may spread to your pump or other drives and that will be very expensive.
brad:)
Sep 13, 2009 | Garden
Problem with left side hydrostatic transmission
This is a well documented problem with cub cadet ZT transmissions. They tend to go bad after 200 hours of use. Sometimes having the dealer change the transmission oil will help (they need to remove the transmissions to do this!). Most times, the transmission is gone & must be replaced ($800-$900).
Sound to me like a design defect. My ZT-50 lasted only 4 years. Needless to say, the replacement was not a cub cadet.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
730 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
