Question about Optics
How to replace fuel lines on chainsaw.?
Model ozpcs305a
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 110 Answers
Before you take the old gas lines off take a photo of them. One goes from the tank to the bulb. The other goes from the tank to the carburetor. Take off the tank and remove the lines with needle nose pliers. Cut the lines into the tank at a 30 degree angle and push through the hooked in the tank. Attach the filter. Make sure when you pump the bulb air is going into the tank, and fuel into the carburetor. Take your time and you can do it.
Posted on Jan 31, 2018
SOURCE:
SOURCE: Replacing a fuel line for a Poulan 2175 type 2 chainsaw
Take top cover off(3 screws). Take off the 2 nuts holding the carb on. Pull carb part way out to access the hoses. Remove the 3 old hoses after making a diagram of where they connect. Buy new hoses. Cut one end of the small hose on a bevel, pierce both sides 1/8 th inch from the end with a needle. Thread a thin wire through both holes. Thread both wire ends into the gas tank. Use a hemostat or long needle nose plyers to pull the wires and then hose down into the tank. Attach the weighted fuel filter. The other end of this smaller diameter fuel line goes on the upper nipple on the carb. Take the side cover off (4 screws) to access the primer bulb. Take 2 screws out to remove the bulb which has 2 nipples. The longer nipple connects to the larger diameter hose which goes to the fuel tank. The larger diameter tube has a coupler on the end which is inside the gas tank. It took me an hour to change all 3 hoses.
Bob
Posted on May 14, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
dontbother10
  • 2220 Answers
SOURCE: Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
  • 4088 Answers
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Posted on Jul 16, 2010
What year was a colt single action - round barrel - serial # 8895 revolver made & what model is it ??
You need the Model as 'Colt Single Action doesn't provide enough information. The Colt site is the best one as is their numbering system..
1973
1971 1851 Navy Model .36 Caliber 1971
1851 NAVY (.36 CALIBER) 1959
PYTHON MODEL 1956
TROOPER MODEL & .357 MODEL 1942
COMMANDO 1937
ACE MODEL .22 1935
OFFICIAL POLICE .22 CALIBER MODEL 1934
OFFICERS MODEL 1930
SUPER .38 MODEL INCLUDING SUPER MATCH .38 1919
WOODSMAN .22 AUTOMATIC 1918
MODEL 1911 MILITARY 1912
"POLICE POSITIVE .22 TARGET, MODELS G & C" 1911
1908 HAMMERLESS .380 1911
1905 .45 1909
1908 HAMMERLESS .25 1908
POLICE POSITIVE SPECIAL & DETECTIVE SPECIAL 1906
POLICE POSITIVE .38 1906
MODEL 1902 SPORTING 1904
1903 HAMMERLESS .32 1903
NEW SERVICE & SHOOTING MASTER & 1917 1900
NEW POLICE .32 & NEW POLICE TARGET 1896
NEW POCKET MODEL 1892
"NEW ARMY & NAVY MODELS 1892,94,95,96,1901 & 03" 1890
1889 NAVY 1889
LIGHTNING MAGAZINE RIFLE-SMALL FRAME .22RF 1885
MEDIUM FRAME MODEL 1882
1878 FRONTIER REVOLVER 1881
1878 HAMMER SHOTGUN 1878
NEW LINE .38 POCKET 1878
MODEL 1877 LIGHTNING REVOLVER (.38) & THUNDERER (.41) 1877
NEW LINE .41 POCKET 1875
NEW LINE .30 POCKET 1875
NEW LINE .32 POCKET 1875
CLOVERLEAF HOUSE MODEL .41 1874
OPEN TOP POCKET MODEL .22 1874
NEW LINE .22 POCKET 1874
SINGLE ACTION ARMY & BISLEY REVOLVERS 1864
1855 SIDEHAMMER .31 CALIBER 1862
1861 NAVY 1862
MODEL 1862 POLICE AND POCKET OF NAVY CALIBER (.36) 1861
1860 ARMY (.44 CALIBER) 1856
1855 SIDEHAMMER .28 CALIBER 1855
MODEL 1849 POCKET-LONDON 1851
1851 NAVY (.36 CALIBER) 1850
2nd Model Dragoon 1849
BABY DRAGOON
colt single action revolver serial numbers Google Search
Jan 23, 2018 | Optics
I got a win model 70 308 serial number 862911
You don't say, but I presume you want the date of manufacture?
http://oldguns.net/sn_php/winmods.htm
Other info for you.
  1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
  2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
  3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
  4. Related searches for win model 70 308 serials
  5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
  6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
  7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
  8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
  9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
  10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
  11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
  12. Pagination
May 24, 2016 | Optics
Looking for what year my Winchester model 94 was manufactured in. The serial number is 2374881
Here you go. These sites will help you.
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 108 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · Serial Number info for Winchester Model 94 User Name: ... Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 ...
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, ... Our database contains values of serial numbers through 5103248 which ended the year ...
  • Model 1894 (Mod 94) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 1894 (Mod 94): ... Please enter a serial number and click the submit button. ...
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm Winchester Model 94 Serial Numbers. In 1894 Production began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or less, ...
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification ... The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • winchester 1894 serial number decoder ' Jeremy blog fitubangscam.blog.com/2013/05/04/winchester-1894-serial-number-decoder Ladder sight CARBINE Winchester 1873 1892. Winchester Model 1894 - Wikipedia, the. Winchester 1894 Serial Number ' Gun. Winchester Model 94, winchester model 94 ...
  • Winchester Dates of Manufacture - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... (Mod 94) Model 1895 Model ... Model 59 Shotgun ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms How can you find the age of a Winchester Model 94? ... What is the age and value of a Winchester Model 94 serial number 3910875?
  • How do you find out if a Winchester Model 94 is pre-64 ... https://answers.yahoo.com/question/index?qid=20081128210042AA3vaql
    • RESOLVED
    • 14 POSTS
    • 13 TOTAL ANSWERS
    2008-11-28 · Best Answer: The serial number is the best bet 95s had grip safeties as late as my 1982 model Put the serial number in here and it will give you ...
  • Dates ' Winchester Collector winchestercollector.org/dates Serial Number. Get Manufacturing Date . Manufactured Date. ... History of Winchester; Winchester Model Information; When Was Your Winchester Made? Winchester ...
  • http://www.bing.com/images/search?q=winchester+model+94+serial+number+decoder&FORM=HDRSC2
    May 22, 2016 | Optics
    Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
    Hello Mark
    my connection here doesn't permit weapons searches, but all the info is below.
    Serial Number info for Winchester Model 94 - The Firing Line Forums
    https://thefiringline.com/forums/showthread.php?t=322230 Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden ... a rusted $50 tomato stake Standard Carbine, or a $10-20,000 Special Order ...
    Winchester Model 94 32 Winchester Special. ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-94-32-winchester-special.-... My question is why is there so much variance from site to site on this model gun. I have one with a serial number 115,814. According to most sites that serial ...
    Winchester Rifles Modern Lever Model 94 Pre 64 For Sale ...
    www.gunsamerica.com/Search.htm?C=767 108 Listings - This is a pre-64 model, serial number 14375xx, and features a straight grip .... Winchester Model 94 Top-Eject Lever Action Carbine .32 Win Special ...
    Winchester Model 94 - Gun Collections Online
    guncollectionsonline.com/winchestermodel94.htm Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .22 magnum, .38 Special/.357 Magnum, .44 Special/.44 Magnum, .45 Colt (or .45 Long Colt), ...
    www.savage99.com/winchester1894_dates.htm Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
    Winchester Model 94 (.32 Winchester Special) - YouTube
    2q==? 7:01 https://www.youtube.com/watch?v=fNRDe5H--S0 Nov 24, 2013 - Uploaded by 88zukcrawler Short video of my favorite gun....the Winchester 1894 (94). Mine is a post 64 model (1972 year by the serial ...
    Model 1894 ' Winchester Collector
    winchestercollector.org/models/model-1894/ .32-40 - introduced in 1894 ... .32 Winchester Special - introduced in 1901 ... As serial numbers approached the one-million mark, the official model designation ...
    Winchester Serial Numbers - ProofHouse.com
    www.proofhouse.com/win/index.html Model 1885 Single Shot · Model 1886 · Model 1892 · Model 1894 (Mod 94) · Model 1895 · Model 53 · Model 55 · Model 64 · Model 65 · Model 71 · Model 88
    Feb 29, 2016 | Optics
    I need a users manual
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    Jan 09, 2016 | Cell Phones
    What is the gap between the ignition coil & the magnetic cup pls?
    just use a business card between the coil and the flywheel magnets--that should give you close to the proper gap
    Sep 05, 2015 | Garden
    How do i serviced the fuel system on the OZPCS305A chain saw
    first check for split in Primer bowl.
    Check to see if Heaver fuel filter in the tank broke off the end of the gas line. That's typical with this horrid Ethanol Gas.
    Dec 16, 2014 | Garden
    Instructions for 2006Painted Imaganirum Table Table
    A.T., VIN model "C" (4x2), TH400, 6 cyl
    A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-305 (5.0L)
    }A}}400}466495" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-350 (5.7L)
    }A}}400}466496" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-379 (6.2L, diesel)
    E>}B}}400}466497" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH700, diesel
    A.T., VIN model "K" (4x4), TH400, 6 cyl
    B@}}}400}466499" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH400, 8 cyl, diesel
    A.T., VIN model "K" (4x4), TH400, 8 cyl, gasoline
    A.T., VIN model "K" (4x4), TH700, diesel
    FFC}B}}400}466502" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "C"
    FFC}A}}400}466503" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "R"
    ECB}B}}400}466504" type="radio" name="userInterchange" />M.T., 4 spd, 4x4, (VIN model "K")
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    A.T., VIN model "C" (4x2), TH700, gasoline
    F=A}B}}400}466508" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH700, gasoline
    }B}}400}466509" type="radio" name="userInterchange" />A.T., VIN model "R" (4x2)
    Oct 20, 2012 | Cars & Trucks
    What year/model transmissions will fit a 1989 GMC sierra, 2500, 350 engine, 2-wheel drive? Thanks
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    Jan 14, 2011 | 1989 GMC Sierra
    Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
    1935 KIRBY Model R*
    19?? KIRBY Model 2R
    19?? KIRBY Model 3R
    19?? KIRBY Model 4R
    19?? KIRBY Model C
    1939 KIRBY Model 2C
    19?? KIRBY Model 3C
    19?? KIRBY Model 4C
    Model 505 - 1945
    Model 508 - 1948
    Model 509 - 1949
    Model 510 - 1950
    Model 511 - 1951
    Model 512 - 1952
    Model 513 - 1953
    Model 514 - 1954
    Model 515 - 1955
    Model 516 - 1956
    Model 517 - 1957
    Model 518 - 1958
    Model 519 – 1959
    Model 560 - 1960
    Model 561 - 1961
    Model 562 - 1962
    1963/64 Sanitronic VII (Sirocco)
    1965-67 Dual Sanitronic 50 (Sirocco)
    1967-70 Dual Sanitronic 80 (Avocado green)
    1970-73 Classic 1CR (Medium brown, gold bag)
    1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
    1976-79 Classic III 2CB (Candy-apple red, plaid bag)
    1979-81 Tradition (Dark blue; intro of paper bag)
    1981-84 Heritage (Gray/orange)
    1984-89 Heritage II Legend (Charcoal/gray/red)
    1989-90 Legend II (Dark rose-pink)
    1990-93 Generation 3 (Alabaster)
    1993-96 Generation 4 (Medium gray)
    1996-99 Generation 5 (Maroon)
    1999-01 Generation 6 (Black/Yellow)
    2002-05 Kirby Ultimate G
    2005-06 Kirby Ultimate G Diamond
    http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
    Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
    Optics Logo
    41 people viewed this question
    Top Optics Experts
    Marvin
    Marvin
    james laughton
    james laughton
    ray gallant
    ray gallant
    Are you an Optic Expert? Answer questions, earn points and help others
