Question about Kenmore Refrigerators
I have a 59669279993 model and the temp. in main compartment stopped being cold but the lower freezer area is cold but not as cold as it should be.
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 30, 2009
Why the freshfood compartment is to cold
There are 2 sets of controls on your refrigerator. One controls the thermostat The other controls a damper door that allows some of the cold air from the freezer to reach the fresh food area . It sounds to me like you are adjusting the thermostat when you need to be adjusting the damper door.The damper door (depending on the model) will have a mechanical linkage or a potentiometer( adjustable resistor control) and a servo motor that directly controls a door that lets more or less cold air in from the freezer compartment, you need to check the position of this control and door to see if it is working properly. If not repair the damper If it is working properly then you could have a defective thermostat.
Aug 01, 2014 | GE Refrigerators
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Fridge section of fridge freezer not cold despite turning thermostat to max. Freezer section appears to be working fine.
Make sure that if it has a "colder" knob in the freezer section that it is not set all the
way over to coldest. This blocks all cold air entering the lower compartment when
set this way. It actually has been eliminated on some models.
Also you may have ice buildup in the stack assembly that feeds
the lower compartment or even a frozen upper compartment behind the back
panel of the freezer limiting air flow to the lower compartment. Make sure to unplug unit if service is necessary in these areas. I hope this is helpful.
May 02, 2011 | Microwave Ovens
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig does not turn itself off except at very low
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
