Question about Canon CanoScan 4200F Flatbed Scanner
Canoscan 4200F problem with copy function
Copy function will not work. I have uninstalled software and reinstalled. I get a message that Canoscan has encountered a problem and must close
  • nelsinho Mar 03, 2008
    I have the same problem and after if I try to scan I get a message saying that the scanner is not proprely conected and some kind of a problem with a twain source........i still have not solved it . if you did please let me know
    thanks Nelson ..Rio the janeiro - Brasil
    Scholar:
  • 111 Answers
Do you also have an HP printer on All-in-one installed? There may be a conflict with the HP driver.
Posted on May 09, 2008
Film scaning options are missed in Select Source
I had the same problem. My solution is: "Just go to settings on Canoscan Toolbox. Then go to copy button, drop down and select scan2. This comes "Copy" as default setting. Change it to scan2. Click ok. On Canoscan toolbox main interface click scan2 and bingo, you'll see film option on select source . Hope this works
Jan 30, 2011 | Canon CanoScan 4200F Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
Can a canoscan 4200F work with a macbook?
Have a look at this site.
They are discussing scanners and Macs here>
http://macosx.com/forums/mac-os-x-system-mac-software/275856-driver-my-canoscan-4200f.html
Jul 10, 2009 | Canon CanoScan 4200F Flatbed Scanner
Canonscan 4200f - docs are dark in color and hard to read
you scanner has no replaceable parts in them its sounds like a board issue.
you could try to take it apart and clean the optics but i would be thinking more of a board issue
Mar 05, 2009 | Canon CanoScan 4200F Flatbed Scanner
Lost software
You can get the software with on the Canon Home page
http://www.canon.com/
click on support or drivers then search your model
Jul 12, 2008 | Canon CanoScan 4200F Flatbed Scanner
Canon Canoscan LIDE 30
For some reason, there are some HP model printer drivers that cause problems with the Copy function of the CanoScan Toolbox. Because of this conflict, when Toolbox Copy function connects with the printer driver, which is what it is doing when you select it from the dropdown. There had been some updates to the Toolbox software that corrected the issue. However, then HP release some new drivers for some models that reinstated the issue.
So the first thing to try would be to download and install the most current version of Toolbox for your scanner model (ver. 4.1.3.5).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
If the problem isn't corrected with that, then you won't be able to use the COPY function unless HP updates there printer driver to correct the issue. If you really must have the COPY option, then you might try using a older Toolbox just for that feature. If that is a consideration, then get the Toolbox ver 2.2.3 from the CanoScan N650U download page.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6858
The COPY function from this version should work fine with the HP printers.
Good Luck.
Apr 28, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
CanoScan 4400f
uninstall all drivers and software that cam with the scanner, and then try installing the software again before connection the scanner... this is a problem when there are two different twain drivers, look for C:\Windows\twain_32\CNQ4803(2) see if there is a driver in there.
Dec 22, 2007 | Canon CanoScan 4200F Flatbed Scanner
Cannon scan 4200f light stays on
There is a lamp shut-off time adjustment in ScanGear. Go into ScanGear's Advance Mode and click Preferences. One of the four tabs will have an option for Lamp Shut-Off time. Set it as desired.
Dec 02, 2007 | Canon CanoScan 4200F Flatbed Scanner
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
128 people viewed this question
old marine
old marine
