Question about Garden
After 5 uses my brutus B & S power washer has
After 5 uses my brutus B & S power washer has not pressure. can you help . I have done everything the owners maual suggests
5 Suggested Answers
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
  • 13 Answers
SOURCE: hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
Posted on Aug 08, 2009
supernova278
  • 1932 Answers
SOURCE: i am looking for a
Hi.
You can download from below website
http://www.peavey.com/assets/literature/manuals/Classic30_manual.pdf
Thank You
Posted on Sep 18, 2010
  • 12 Answers
SOURCE: i have a brutus hifonics brz1200 amp, everythings
check for defective rca wires. maybe a sub terminal has broken off? defective pre outs on headunit?
Posted on Sep 13, 2011
Why does my Karcher pressure washer Pulsates when switched on also leakes water.
Shame you did not leave the model type of "Karcher" pressure washer as there are several models.
There is normally a special oil which should be changed, expect this to be done at least every three years or less.
1/. These pressure washers should only be serviced or taken apart at one of their registered dealers, as far as pulsating if you have the cheaper models then they do not last very long.
2/. Their better more power washers pulsate all the time & that is why they are sold new with a special fitted container, this allows all the pipes & water connections to fit & hold in supplied container, which allows you to give a higher or lower power controller where their yellow pipe that attaches to the gun fits on the machine.
3/. Where the pressure pipe goes into the power washer it has a black knurled fitting to adjust the pressure higher or lower out put, this is the only adjustment you can make on these power washers, everything else needs to be done by their approved dealers, situated all around the world, try finding your nearest dealer through the Internet. Hope this helps. Malcolm.
Feb 07, 2015 | Karcher Garden
Brutus elite hifonics BRE1600.1D. Not as powerfull now.
Make sure of voltage going in to Brutus.
Mar 23, 2014 | Car Audio & Video
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
I have 2 12 inch jl audio w7's with a kicker crossover and a powerbass equalizer 5 bands. i wanted to know if add a hifonics brutus 2100 d class amp to my subs at 1 ohm would it over power my subs. please...
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Dec 22, 2010 | Hifonics Car Audio & Video
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Amp does not work
make sure your power and ground wires are 4 gauge thats a big power puller also make sure your wires to woofers are correct!and you want a short ground wire and a good spot for it no paint!!
if there out of phase that will shut it off BUT you might be needing a battery cap. MORE POWER!!!!they dont cost much
and save your battery and alt.hifonics is a good choice my favorite are the series 7 they dont make them like that anymore!
hope this helps one more thing your alt.how many amps is it?
my honda is only 60 amps your brutus pulls that all day !
(BATT.CAP.or HAVE ALT.WRAPED for more power.
Dec 01, 2007 | Hifonics Brutus BX 1505D Car Audio...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
