Question about Garden
3.75 hp engine - done 3 seasons lawnmower. Has been running fine till yesterday. All of a sudden the power just faded away. I thought the engine was going to conk-out, but it just kept on sitting there simpering. I have cleaned air filter and inside of carb. No better. Can you suggest anything else? Thanks Dave Grant in Scotland
    Scholar:
  • 45 Answers
You must clean out the float bowl under the carb. Find the hex nut at the center bottom of the bowl to remove. There will be dirt and/or water.
Clean the hex nut too. It functions as a jet and has a small hole in it.
Dran a bit from the bottom of the fuel tank to. Your problem is indicative of water being sucked up from the bottom of the tank.
Add some fresh fuel and a biot of "gas Dryer" methanol.
Posted on Jul 30, 2009
Testimonial: "Hello Fixya, sorry delay. My eng small-carb built into fueltank-but answer great It got me into carb diaphragms, I replaced - mower now ok, Many Thank"
  • 26 Answers
Try checking you oil.if it is not low then check the compression to see if your rings or valves are waring.if all that's good then it has to be the carb. either the float is sticking or there's a fuel problem somewhere
also the spark-plug maybe loose. see if it runs better when is is choked if it does then you may not be getting the proper fuel presser check the lines and filter you may have a small fuel leak.
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
The snow blower runs but when I begin to blow snow it dies and won't start right away
try running a can of automotive carb cleaner thru the tank of gas the type that says cleans as you drive on bottle this helps sometimes and keeps you from having to remove and tottlay clean out carb from stale gas being left inside it
reminder: allways run seasonal engines till there out of fuel before putting away for season , that way they tend to start right back up in season with a fresh tank of gas !!!
Feb 24, 2015 | Garden
220.brigs and Stratton oil how much insump
A small qt bottle of SAE 30 wt oil, of ANY brand is fine for use in lawnmowers. The tolerances for the piston ring and cylinder are not so close to warrant more expensive synthetic blends. A simple std grade (cheapest) 30 wt is fine. It is a good practice to drain and refill your lawnmower engine before each cutting season, replace the air filter, and spark plug. Carburetors tend to foul so empty the gas tank at the end of each cutting season by letting the mower run out of gas... empty the float bowl, if it has a drain screw... this will keep varnish and gum from forming when you store it. Keep a spare cord on hand as they break when you least expect them to and when you need to use the mower. Hardware stores sell replacement cord, just cut to lengths as needed.
Oct 11, 2014 | Garden
I have a 2001 tj magna solara.all in well maintained condition.Have suddenly had the transmission fade to nothing over a two week period.could this be electronic selection or transmission gone.can u o
check transmission oil level. check colour of the transmission oil. change it tan not red. check filter in the box for blockage. ( failing clutch material. run fault codes and check TCM for faults. have a pressure test done on the box to check for mechanical faults
replacement box is the absolute last option
Sep 10, 2014 | Cars & Trucks
I have a few horizontal wavy lines at the top of the screen when I first turn on the TV. They eventually fade after a few minutes. What's going on? Is this serious?
yes it is, your hyper board has bad caps and they will just get worse and worse. you can run it on an HD signal to keep it going longer but eventually even the HD will have the wavy lines too.. basically the hyper board needs new 10uf 16v surface mount capacitors, replace all those and your golden, but its a difficult repair, even for a educated and seasoned electronics tech, estimate from repair shop will run you $250-$550
if you can solder surface mount, you can fix it yourself for like $20
let me know if I can provide further assistance
Sep 09, 2010 | Toshiba 42H82 42" Rear Projection...
My unit has been running great up till now. Just
Check compressor for high current consumption.Check capacitors. Check fan speed.
If fan speed is low compressor will over heat and trip safety circuit in the compressor. If there are independent fans check both of them.
May 26, 2010 | Mitsubishi MS-A12WA Air Conditioner
Screen faded (a bit Whitened) all of sudden and the battery back up gone down siverely
Honestly i have dropped my E61 a couple of times at the hight of atleast 4 to 5 feet. it still is working fine, yours could be a hardware problem.
Dec 16, 2007 | Nokia E61 Smartphone
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
