Question about Bissell 7950 ProHeat Upright Wet/Dry Vacuum
Over heated Smke suddenly started coming out of the handle. I have used this cleaner my second time now. I checked everything, and after awhile, it will not come on.
  • cecilloubeck May 13, 2009
    I have a bissell upright wet/dry unit model 7901-1. I have had the unit several years but have never used it until today,so there is no warranty issue. After using the unit about one hour is stopped working. The red light on the front was on so power was going to the unit. I opened the unit up and the control board in the handle was extremly hot.
    The machine was not dirty or anything like that. What might be my problem?
    There is no Bissell service center in my area.
  • 1,673 Answers
In the handle are a heater, transmission and a circuit board. If you have smoke come out and now it doesn't work, I would suspect the circuit board of being bad. If this is less then 2 years old, then it is still under warranty.
Call BISSELL Consumer Services at the number below or visit the BISSELL Website - to locate a BISSELL Authorized Service Center in your area.
Website or E-mail:
Select "E-mail BISSELL"
OR Call:
(800) 237-7691
Monday - Friday 8 am - 10 pm ET
Saturday 9 am - 8 pm ET
Posted on Feb 05, 2008
My bissellpro heat is making a loud noise as I clean carpets. What can I do?
If the belts are good and not slipping, the noise could be a bearing issue.
Oct 02, 2017 | Vacuums
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Broken/snapped off handle with minimal use...twice...two differen
The shark has a one year warranty... send it back ...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
Mar 04, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Dec 14, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat Clearview 1669
Take out the 2 long screws with the nuts on them, then furher down just beneath the hose wrap asm, there are 2 more screws to remove. Put the top part of the handle off, lay the handle down, on the front, at the top and in the center is a tab, push it in and pull the top half of the handle away from the bottom half. Then you will see the heater, don't mix up the hoses after you are done.
Jun 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Scunci steam cleaner not spraying steam
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
May 24, 2008 | Scunci 52067 Handheld Steam Vacuum
Carpet Cleaner Brushes
It uses a cogged belt, check the belt, also check the pulley, if the cogs are worn down, then you will have to replace the pump, the pulley comes with the pump.
Mar 24, 2008 | Vacuums
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Cleaner suddenly stopped working
Based on the other solutions I read, I also traced the problem to clogged input/output ports to the heater. I hadn't used the cleaner for about 2 years and the ports were blocked by calcium and mineral deposits. I took the manifold cover off the bottom of the heater and carefully reamed the ports out with a finishing nail. I then cleaned the ports and manifold with Lime-Away to dissolve any other deposits. I put it back together (with no parts left over!) and it works fine.
Oct 15, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
309 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
