Question about Dryers
Whirlpool electric dryer will not start Model # ler6644dqo
    Scholar:
  • 45 Answers
One of serveral fuses is burned out due to an overheat condition.
OR the belt is broken
If you hear no noise at all it is the fuse.
You must first fix the overheat problem by opening and cleaning out the cabinet.
Unplug
Remove the screws at the filter screen and use a putty knife to release the two clips holding down the top at the front.
Tilt the top cover up.
Remove the front cover by removing the two screws at the top of front cover (from the inside) then lift up the cover.
Remove the Belt and drum
Vacuum everything out
Check the fuses for continuity. Replace bad fuses.
Reassemble and run.
If it is worse than that, then don't bother.
Posted on Jul 30, 2009
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Dry won't start when button is pushed yes it has
Bad door switch, possibly. Wire slide connector on the door switch is loose, possibly. These are really simple to fix.
Apr 07, 2010 | Whirlpool WED5900S Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
114 people viewed this question
Top Dryers Experts
