Question about GE (PSS26MSRSS) Side by Side Refrigerator
G.E. side by side Freezer Coils and back wall full of ice.
G.E. side by side model TFX24PATAWW freezer coils and back wall fills with ice. Box not as cold due to ice build up replaced the timer clock but box fill up with ice again. What do I doo next
  • 560 Answers
If you replaced the "defrost timer", and the circulation fan runs ok before the ice buildup occurs, you will have to melt the ice so the panel will come off. Then, pull the back panel off and inspect to components. First, the defrost element and connections to it. If connections are good, disconnect 1 connector and check the resistance of the element itself with a ohmmeter. It should be 40-150 ohms, depending on the unit. If it is excessive or infinate, replace the element. If it is ok, leave the element disconnected and check the other component (defrost termination switch) which is clamped onto the evaporator coil and has two wires attached to it. It should read 0 to 2 ohms at room temprature, and no more than that as it is a temprature controlled switch. If it has excessive resistance, replace it. These are the only 2 components, aside from the defrost timer, that encompass the entire defrost circuit in most refrigerators.
Posted on Jul 31, 2009
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Jul 30, 2016 | Frigidaire Refrigerators
Model EP1chexbq00 no airflow on bottom: top freezer works but not bottom. Fan works.
Ok one of two problems. Either you have an ice block or you have a plugged drain. If you have a couple of dif choices. If you have a back up fridge than fill it with the contents of the broken one. Unplug leave doors slightly open for about 48hrs. Have towels for the water from the ice. Usually 2 or 3 bath towels. Plug back in and if the problem happens again within a week than your bi-metal ( defrest thermostat) is bad. To replace you have to remove the back panel in freezer and and on the condenser coils near top you will see a little round silver part.
Option 2- If no backup fridge or you have time. Have a hair dryer, 3 bath towels, a 1/4 inch nut driver (may be phillips) for screws. Unplug fridge and open freezer. Remove contents and place in ice chest with ice.remove screws from back wall pull panel forward. If you have an ice maker ther are two screws on the top where the ice fills at and one at the bottom. Also disconnect the quick connect for the ice maker. Remove back panel. You will see one of two things either all your coils are iced up (frost on all coils is normal) or two where it drains on silver plater has ice blocking drain hole. If ice is blocking drain remove and pour hot hot water down drain until it flows into drain pan in the back of fridge by compressor. If the coils are all iced up have towels ready. Start by putting a towel where it would normally drain where the towel is soaking up the water. Turn hair dryer on and melt ALL thee ice. some ice will be in the middle of coils and in back where you Cant see. Keep the hair dryer moving sitting in one place too long can damage wire and the walls of freezer. Melt all ice until no more water is falling from condenser coils. Than you will have to replace the bi metal. Put everything back in and plug in wait about 2 hrs before putting contents back in freezer. Just to let you know the the fridge will NOT cool down until freezer gets down to temp. Than the air will start cycling into fridge. If you have anymore question please feel free to comment me back for further assistance.
Jun 05, 2011 | Whirlpool Refrigerators
Refrigerator not cooling and freezer has ice on back wall. This is a Kenmore Freezer top unit. The model number is 363.9735728. Condenser coils underneath and in back were covered with dust 1/4 inch of...
Unplug the box and let the freezer completely defrost (4 hours or so with the freezer door open - put towels at the bottom to collect condensate). If this is the problem, the freezer will work great for a day or two after defrosting, then get progressively warmer.
If, after you restart, the freezer freezes up again, it's probably a failed defrost timer. The defrost timer shuts the box down ever 12 -24 hours, turns on a heater coil to defrost the freezer coil, then restarts the compressor.
After the ice forms, the freezer can only reach 32 degrees. It should be at about Zero degrees when it's working right.
It's POSSIBLE that the problem is the defrost heater, but a defective defrost timer is far more likely.
Aug 02, 2017 | Refrigerators
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cool enough even on higher settings
I posted this on another problem, but this may help you too.
Check to see if there is frost on the back panel of the freezer.
If there is try solution below:
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE GSS20IEP Side by Side Refrigerator
Refergirator not cooling
Defrost system failure.
Defrost system: Freezer fan, Defrost timer, Heater, Thermostat. If any one of these are bad the coils in the freezer will get clogged with ice and not allow the cold air to circulate over to the ref. side.
Ice/frost build up on the back wall of the freezer is an indication of this problem. You can manually defrost with a hair dryer which will give you a couple of days before it starts iceing up again. Remember, the ice you see on the back wall is just the tip of the iceburg, there is a lot more on the coils behind that wall.
Jan 06, 2009 | Amana ARS2464B Side by Side Refrigerator
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
GE fridge TFX24FHB mfr'd 7/86 - system check display shows "de"
This may or may not be the fix, but I had a problem with my GE Profile TFX24PR sibe-by-side. Water was leaking from the ice maker water fill tube into the back of the freezer, onto the cooling coils. This would cause the freezer to go into extended defrost and the freezer and fridge would warm up. If you see ice inside the freezer, especially around the outside of the ice bin, or odd chunks of ice in the ice bin, turn off the ice maker and/or the source water supply and see if the problem clears up. If the ice buildup is especially heavy, you may need to remove your food, and unplug and manually defrost/thaw the freezer. You may want to remove the cooling coil cover, that is the back wall of the inside of the freezer. Mine had five screws holding a thin sheet of metal, three at the top and two near the bottom. Once this is off you can see the cooling coils. Be careful not to bump or scrape the coils. At this point I found about a quart of ice frozen on top of the coils in one big chunk, stuck to many wires. I carefully broke off what ice I could, and used a hair dryer to melt the rest.
If this is the problem, then you will need to replace the ice maker water fill tube. This is a time consuming job, you have to disassmble the fan compartment on the back wall of the freezer behind the ice maker to get to the fill tube connector. Once you get there it's easy to reach and it just pushes into the connector. In my case, I just reversed the ends and pushed it back in for a snug fit. You may want to consider using a sealer to prevent it from happening again any time soon.
Dec 21, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
321 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
