Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
Corrupt files i have one computer that connects just fine with the dlink dwl-g510 and when i tried another computer in my house i can't get anything. it says ''the capabilities of the wireless network adaptor or wireless settings on this computer do not match the requirements.'' the only difference is the manufacturer. one is hp one is compaq they are both windows vista 32 bit operating systems and also when i try to extract from zip it says its corrupted
Check ur wireless nic card first..if not go 2 the control panel check for the new device wizard 2 detect ur device..and if ur NIC is detected and works..get 2 ur wireless setup wizard in CP..it ll guide u..if ur problem is still not solved pls check for u router's LEDs r working if the DSL or uplink,eternet light blows constantly..if it takes a sec of interval for each blow contact ur ISP...
Posted on Sep 03, 2009
I can't download the sofware to operate my DWL-G510 PCI adapter, the software i got with the card is not working partially.
I understand that you are not able to download the installation software for the adapter DWL-G510 adapter.
Regarding the concern, please visit the below link to download the required software:
http://www.dlink.com.au/tech/Download/download.aspx?product=DWL-G510&revision=REV_C&filetype=Drivers
I hope this information allows you to resolve this issue. Please revert back for any more assistance on the same.
Regards
Anand
Mar 24, 2011 | D-Link FREE DLink DWL-G510 802.11g...
Where can i download a config utility for my D-LINK AIRPLUS DWL-G510 ADAPTER
Here is the site for the driver.
http://www.dlink.com/products/?tab=3&pid=DWL-G510&rev=DWL-G510
Dlink does not have a configuration utility for this device, so it may be that there was not one offered. Instead you can use the zero configuration utility with Windows XP.
It also states that this device has been discontinued; the driver is the 1st release driver and has not been updated.
select the DWL-G510 driver to download it, or if you have the h/w rev.2 click the FAQ and select the option for a missing "wlanapi.dll" file. There is an updated driver for this revision on the link to that FAQ resolution. For ease of use it is here:
http://www.dlink.com/products/?tab=3&pid=DWL-G510&rev=DWL-G510_revB
Good luck and I hope this helps.
Feb 24, 2011 | D-Link AirPlus G DWL-G510 802.11g/b...
Dwl-g510 can not connect to the inernet although widow 7 recognizes it
you need to update your drivers for this device or check to see if its compatible with windows 7 on the dlink site
Apr 26, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
I'm trying to connect to my wireless network using the d-link Airplus G DWL-G510. I can't get a connection. In the Site Survey is shows about a 50% but won't connect. My Wii uses the wireless router and my...
Ah...found it!
I think that with XP service pack 3, it caused a problem with the wireless card driver.
I just installed the latest driver, and it connected for me without a problem. Here's a link to the driver:
http://www.dlink.com/products/?pid=DWL-G510&tab=3
Hope this helps!
Jan 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
Cannot get drivers to download for dlink dwl-g510
One way to get online is to get a usb to ethernet adapter, then go to the manufacturers website, be it the computer manufacturer such as dell, or the motherboard manufacturer. However, I noticed you mentioned a dwl, are you using exclusivly wireless for this PC? Also, what is the error you are receiving?
Mar 19, 2009 | D-Link FREE DLink DWL-G510 802.11g...
Need cd for my wireless adapter
Here are the drivers:
The hardware version is given on the bottom of the device. Example: H/W ver.:A1 or H/W ver.:B1
If you have DWL G510 rev A:
ftp://ftp.dlink.com/Wireless/dwlg510/Drivers/dwlg510_driver_100.zip
If you have DWL G510 rev B:
ftp://ftp.dlink.com/Wireless/dwlg510_revB/Drivers/dwlG510_revB_drivers_S0031.zip
Jan 11, 2009 | D-Link FREE DLink DWL-G510 802.11g...
What chipset?
Kim:
http://support.dlink.com/products/revision.asp?productId=DWL-G510
find which product is yours and look inside and go into knoledge base.
Kim: if that specific info happens to be avaliable online it most likely be here http://support.dlink.com/SupportFAQ/default.asp?model=DWL%2DG510 (model a) or http://support.dlink.com/SupportFAQ/default.asp?model=DWL%2DG510%5FrevB (model b)
.. although I doubt it is as it may be propriatary or only accesible through the technitians at the manufacturer facility... the best you can do is to install the software and test it..
you need to know this item is discontinued
Dec 05, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Dlink wireless Adapter DWL-G510
i need to download software of d link cd
Jan 23, 2008 | D-Link FREE DLink DWL-G510 802.11g...
Lost Cd
Dont worry you can download from D-Link's website. However you need to choose correct Revision (Rev A or Rev B) before download. Its very clearly indicated on the website. You can proceed to links;
driver for Revision A
http://support.dlink.com/products/view.asp?productid=DWL%2DG510
driver for Revision B
http://support.dlink.com/products/view.asp?productid=DWL%2DG510%5FrevB
If you dont know what revision you have you can check these links
for Revision A
http://support.dlink.com/prod_img/revisions/DWL-G510v.jpg
for Revision B
http://support.dlink.com/prod_img/revisions/DWL-G510_revBv.jpg
Jan 15, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
94 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
