Question about Panasonic Lumix 10.1-Megapixel Digital Camera - Blue
My camera when turned on says on the screen. This memory card is locked. How do I unlock the memory card. I can't take photos Thank you
  • 1,511 Answers
Turn the camera off. Then take the memory card out of the camera. On the side of the memory card there's a small tab which slides up and down. Just move it to the correct position.(Unlocked position, it will be marked on it)
Regards. If your problem is solved, kindly do Rate!
Posted on Jul 30, 2009
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
When i try to take a photo the camera says right protect. All the photos are locked. How do i go about unlocking them so I can take new photos? Thank you
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Aug 26, 2011 | Olympus FE-230 Digital Camera
We purchased this camera for our grandson, the problem is the camera appears to be locked. you cannot take photos,in fact alll you can do is turn the camera on. the instructions got colored on sao they...
Hi. I don't know this camera but if it uses a memory card it could just be that the card is 'locked'. Have a look at the card and move the little slider to unlock it.
HTH
Chas
Mar 06, 2011 | Sakar Crayola EZ Grip Digital Camera
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2010 | Samsung Digimax S800 Digital Camera
CASIO camera says screen card is locked, mem. card is on unlock..
thank you very much, it was the card when i removed the card it worked. again thank you
Jun 06, 2009 | Casio EXILIM Card EX-S770 Digital Camera
LCD shows MEMORY LOCKED even thought card is NOT LOCKED!
Go thru all the pages on the camera setup in the camera. You may find a memory lock conrol. That is there to keep you from accidently erasing photos.
May 03, 2009 | Canon Cameras
Cant take photos and the LCD screen says "Memory card is locked. Slide lock to 'write' position"
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
Apr 16, 2009 | Nikon D90 Digital Camera with 18-105mm...
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Panasonic Lumix 10.1-Megapixel Digital Camera - Blue Logo
54 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
