SOURCE: need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
SOURCE: for the rebate It askes for the board serial
Try this link below, you should be able to find the Motherboard Serial number around that area. If your still not clear Email the company and ask them for clear description of the location.
http://www.ecs.com.tw/extra/productinfo/MB.htm
SOURCE: I have been trying to
Hi There,
The seller are right, you should replace using same model number.
For the replacement you no need looking fore the same value, you can replace with higher Voltage (1000 micro farad 16 V can replace with 1000 micro farad 25 V)
Testimonial: "Very helpful and quick replies."
SOURCE: Image on LG 42PC5D-UL is
You've got to go minto your main menu and in the screen position settings you will be able to correct the horizontal offset and the verticle offset. You'll also hve the option of resetting all values to factory default but, I would suggest the former first. Thanks, Dana
