Question about Electrolux Ovens
Electrolux oven eog7330xn stopped working
I have an electrolux oven eog7330xn - and its stopped working. am not technical at all so please help! There is absolutely no power as clock not on - its just blank - plug and fuse working fine so its not that
There doesnt seem to be gas either and no clicking when I turn the dial
HELP
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Posted on Jul 18, 2010
How do I fit a seal to an Electrolux oven with rounded corners and no clips
Good Afternoon friend, thank you for your post!
I understand that you need help with the seal on your Electrolux oven. Could you provide me with your model number, please? The serial tag is located on inside wall of your oven. With that information I can provide you further assistance. -Matt
Feb 12, 2015 | Electrolux Ovens
Electrolux oven wont stop beeping
Hi Friend, I am happy to assist you!
I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
Jul 13, 2014 | Electrolux Ovens
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
Oven overheating
try check sensor thermo..maybe its bad..replace new one.cause its cant control heater.
Jan 29, 2014 | Electrolux Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Ovens Logo
449 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
