Most likely the laser has failed and needs replaced. Here is the documentation.
CA1 Indicates that the polygon motor in the ROS has failed.
Procedure
Enter output test, code 103, GP 10.
The polygon motor runs.
Yes No Unanswered
Perform the following:
Check the connector CN26 on the Interface PWB. Refer to Wiring Diagram 4.
Check the harness and the pin connectors.
Check the Interface PWB for damage.
Install a new ROS, PL 9.10 Item 15.
Install a new Interface PWB, PL 9.30 Item 5.
Check at connector CN26 pin 4 on the Interface PWB for a low signal. Refer to Wiring Diagram 4.
The signal is low.
Yes No Unanswered
Check all the connectors to the interface PWB are pushed fully home.
Check the interface PWB for damage.
Install a new interface PWB, PL 9.30 Item 5.
