Stuck in one channel -- auto program says off -- push + Can't find any + to push
  • 261 Answers
If your TV is a CRT the issue is with the Main Board, but if it's a DLP the issue is with the DMD board
Posted on Jul 30, 2009
I have a LG (42PC5DC ) and it's stuck on Ch.8 and I can't change the channel nor do it have a picture. I have unpluged it to try and reset it but that didn't work.I know you can't give
lg tv can you go to main menu if yes go to channels settings and try auto program if still not then same page it have manual program go to that menu and add channels manualy and then turn off menu .by pressing menu button .and change channels
Feb 23, 2012 | LG 42LC2D 42 in. LCD HDTV
How to program channel without remote
First be aware that if you are using an antenna this television has an analog tuner which is no longer capable of receiving any digital signals which is the only channels being broadcast as of June 2009. If you have a cable or satellite receiver then here is the procedure for auto programing your channels. Make sure your active cable/satellite is plugged into Ant 1 (Antenna 1) on the back of your set.
On the front panel push the menu button until the "Channel" is highlighted. Then push either the plus button or the down button to highlight auto program.
Once that is done push plus or up and the set will automatically tune in all the available stations
Zashiban
Jun 04, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do you program the montgomery ward model number jsj12248 televsion so that you get more channels?
Hi, jsj means it`s built by sharp, you need to auto-program the set, push menu on set or remote and look through the menu settings for either auto-program or add channels , gl, video-tek
May 17, 2009 | Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv stuck on menu
Greetings!
These Orions and the Emerson units built by Orion all revert back to set up after being unplugged for a given length of time. The situation can be rectified on the front panel without the use of remote. Please forgive if this seems over-simplified:
1. Turn on the set.
2. When screen appears push "FF" or "REW" button to select the desired language.
3. Push "PLAY" to move the arrow down to "Auto Preset".
4. "FF" to engage the auto channel programming.
5. When the set is done auto-programming the menu will clear and you use the set normally.
Rob
Jan 14, 2009 | Televison & Video
Channel stuck and can't record shows the same night
Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
-Tha Mp3 Doctor
Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
Tv will not change channels
BAD tuner!! also if you have a vcr use it for your different channels/ set must have EX- AV jacks.
Feb 20, 2008 | Sony KV-35S40 TV
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Can't get any tv reception
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
Aug 18, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
