SOURCE: CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
SOURCE: Compact Flash Problems
Dynamite,
have you tried to reformat the CF card? If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
SOURCE: create a class called Date in C++
I wrote it for you:
date.cpp
date.h
Remember, this is only a demonstration, so you can learn from it!
SOURCE: System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
SOURCE: Nikon Coolpix S710 must set date and time everytime.
add me in i have the same problem (time and date reset every time you turn off the unit) plus s710 hangs when on view mode... is this something to do with the firmware (mine is ver.1.1)........ please help..... its very annoying....
