Question about Kenmore 75180 Wall/Window Air Conditioner
Go to turn the unit on nothing several years old. 18,000 btu electronic pad. circuit breaker fine.
    Scholar:
  • 45 Answers
Unplug the unit for electric power.
Remove the plastic clamshell covers.
Clean out ALL of the dirt and insect debris. You can use a garden hose.
Locate the contactor. It is a box with heavy wires coming out of it which lead directly to the compressor.
Check continuity of the points in the contactor with an ohmmeter. You should see zero ohms across the points (they usually burn out after a few years of use). With the ohmmeter attached, when you tap the contactor box and you see a change in resistance, they are definitely bad.
Replace the contactor or if you are bold enough, drill out the rivets and disassemble so you can see the points, if they are burned, clean and polish them, reinstall.
Posted on Jul 30, 2009
    New Friend:
How to drill out the riverts and disassemble? would you be more specific.
My case I turn on I don't see light or click on pressing power switch. It is digital panel with remote. Please help.
Through wall kenmore 13000 btu 2005.
Posted on Jun 06, 2013
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
Works for an hour then blows warm. shut it off for two or three hours and it works for another hour or two. unit is two years old 18,000 btu unit
Clean the outdoor coil, slide it out of the case and use a garden hose to it, keeping water out of the rest of the unit, sounds like the coil is dirty, clean it good until the water runs clean every inch of the coils and you should be running again.
Jul 05, 2011 | LG Electronic Window Air Conditioner
The panel turns on but the motor does not turn on. The electronic panel is on but the ac has a humming sound without the motor or the compressor turning on.
Hi, This being 18,000 BTU is a 240 volt unit. The electronic in it work at 120 volts. I believe you have only 1/2 the electrical current going to it. Thus the Hum. CHECK YOUR FUSES OR CIRCUIT BREAKER!
A 240 volt circuit breaker has two sides or switches with a bridge between them. One of them may be tripped. Shut off the breaker wait a few seconds then turn it on so that the it engages all the way. It if clicks or pushes your fingers back and prevents you from engaging it, there is a problem likely with the compressor/fan or it's wiring, and it is drawing too much current and requires repair or replacement.
Hope this helps,
Best, Mark
Dec 28, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Fridge keeps tripping the circuit breaker
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Circuit breaker
ngfam1
Happy to assist,
HOW MANY BTU IS THE AIR CONDITIONER?
And is it 110 or 220 line!
If it is using 110 or 115 volts like normal house current and it throws circuit breakers in your electric box,then you need to run a dedicated line just for the Air Conditioner!
Usually this happens to 110 -115 volt air-conditioners that are more than 12,000 BTU and do not have a dedicated electric line in the wall only for the air conditioner!
New air conditioners have a circuit breaker built into the units plug!
And I have seen some that throw that breaker to off frequently even if it's only an electric surge! Which it should not do!
if its the case and it's new, take it back to the store and ask for a different model, size, or brand!
Fedders had an 18,000 BTU/ 110-115 volt unit that did this with every single unit last year! I stopped selling that unit only!!
Ngfam1
PLEASE GIVE ME A GOOD RATING HERE FIXYA.COM BEFORE YOU SIGN OFF!
you can just use it as is as long as it survives!
Aug 29, 2008 | Amana PTH123B35AJ Air Conditioner
Replaced window unit - new one won't power up (2nd model)
green light comes on when reset, when try to test goes out, power does not come on at all
Aug 09, 2007 | Samsung AW0503B Air Conditioner
Kenmore 75180 Wall/Window Air Conditioner Logo
160 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
