Question about Canon CanoScan LiDE 70 Flatbed Scanner
Enable Duplex Scanning
My cousins friend last week scan both sides of my insurance card at once but i forgot to ask her how she did it. Can you explain what i can do in ordert to scan the top and bottom at the same time, so that they can be on the same paper??
  • 490 Answers
You cannot scan both sides using a flatbed scanner! If you want both images on the same sheet, you need to scan twice and using some imaging software you can cut and paste the images appropriately.
S. Mohan
Posted on Aug 07, 2009
Will Only Scan Color and single sided
Once I had a similar problem with CapturePerfect 2.0. No amount of setting will change the scan output. I hit the default option and then changed to the setting I wanted. It worked. May be there is a bug in the Scanning software.
S. Mohan, India
Jan 09, 2014 | Canon DR-3080CII Path-Through Flatbed...
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
No duplex scanning
Try going to the hp solution center
Then settings, scan settings, scan preferences (third from top), under the automatic tab, bottom of list is “Scan both sides of the original when using duplex feeder”
I’m using version 70.0.128.000 of the HP Solution Center if that helps.
I told my brother once to ask HP support about a problem for his laptop, and they proceeded to instruct him how to make the problem worse and royally screw up stuff that was completely unrelated to his problem.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Can aphotosmart c7280 all in ne do duplex printing
The printer’s built-in duplexer lets you print on both sides of a sheet of paper, but there’s no duplex scanning for two-sided documents. taken from Mac Life last sentance 4th paragraph Please rate my service thank you  PJ
Dec 02, 2008 | Office Equipment & Supplies
Canon DR-2050C - Duplex scanning
Try and reinstall the driver software. IF you had scanned only one page and also had chosen multipage option, the second side will not be visible, unless you use a proper software that can display 2nd side.
S. Mohan
Aug 18, 2008 | Computers & Internet
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
101 people viewed this question
old marine
old marine
