Question about Dell Dimension E521 (D10E16) PC Desktop
Boot, black screen, error code 3
The desktop dosen't boot , black screen and Erro code 3 keeps beeping in the front.
It was working just fine few hours ago.
    President:
  • 2,666 Answers
2 short, 1 long
BIOS checksum error
1 long, 2 short
Memory test failure (bad memory during memory sizing)
Posted on Jul 30, 2009
Beep codes on dell xps one 2010
If I understand your issue, it sounds like the display works fine until it loads Windows, and then it has the error? It sounds to me like the video card drivers are crashing. This may be the case if you have recently updated them, or installed a new video card. I would recommend getting the latest drivers from the manufacturer's website on a CD, SD card, or USB drive, and then boot your computer in safe mode. Once in safe mode, install the new drivers, and see if that will help. You could also try using your onboard (integrated) video card if your motherboard has one. This could help rule out if the monitor is at fault. Just make sure your BIOS has the integrated card as a secondary video device if it the (I'm assuming PCIex16) peripheral card isn't found.
Oct 06, 2012 | Dell XPS One All-in-One TV Desktop with...
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
Looking for manual for acer aspire m1201. its on complete lock up powers up and thats it
Please go thru this link to find the manual.
http://support.acer.com/us/en/acerpanam/desktop/0000/Acer/AspireM1200/AspireM1200nv.shtml?Team=%2Fus%2Fen%2Facerpanam%2Fdesktop%2F0000%2FAcer%2FAspireM1200%2FAspireM1200nv.shtml
Feb 07, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
My Sony VGC-RA826G Desktop turns on and then beeps 3 times...monitor has black screen
Sounds like a memory error. Try pulling out one stick at a time until it is able to boot. Assuming, of course, you have more than one stick. If not, buy or borrow a new stick and try that. With 3 beeps the bad stick is likely to be in DIMM slot 1.
here is a description of beep codes for various BIOSes:
http://pulonangka.web.id/software/beep-codes-error-codes
Sep 02, 2009 | Sony VAIO RA826G (VGCRA826G) PC Desktop
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Dell Dimension E521 (D10E16) PC Desktop Logo
259 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
