Question about Garden
When I go to a high pressure nozzel engine quits when I let go of the wand trigger. Found O-Ring on caberator bowl dammaged.
    President:
  • 583 Answers
PRESSURE CONTROL WOUND DOWN TOO FAR CAUSING IT TO SPIKE....WHEN YUO RELEASE TRIGGER CAUSING OVER LOAD ON MOTOR WHICH STALLS.BACK OFF THE PRESSURE CONTROL(THE VALVE THE PRESSURE HOSE SCREWS ONTO)IT MAY TAKE AFEW TRIES TO GET IT RIGHT,YOU WILL SEE THE NEEDLE ON GAUGE JUMP RIGHT AROUNDJUST AS YOU RELEASE THE TRIGGER,THAT IS WHEN IT STALLS TURN ADJUSTER 2 MAYBE 3 TURNS ANTICLOCKWISE TO START WITH GO UP OR DOWN FROM THERE WATCH THE NEEDLE ON GAUGE IT SHOULDNT BOUNCE(SPIKE) ON RELEASING TRIGGER
Posted on Jul 31, 2009
Karcher electric power washer480 .pump runs on when trigger is released there are no leaks . Also i can not turn machine off at the main switch.
If you are unable to shut off the pressure from the wand, there may be an issue with the unloader valve that is stopping it from switching into bypass mode when the trigger wand is released. The unloader valve is designed to respond to the spike in pressure created when the trigger wand is released, and to divert the flow of water coming from the pump to bypass the pressure hose and flow back into the intake end of the pump. If the unloader valve fails to switch into bypass mode, water may continue to flow out of the trigger wand. This may also cause damage to the wand. If you are unable to shut off the pressure from your power washer, stop the engine and discontinue use immediately. The unloader valve should be removed and possibly replaced if found to be malfunctioning. The inability to stop the flow of high-pressure water from the wand can be dangerous and should be fixed before continuing to use the machine.
Dec 28, 2017 | Karcher Garden
Hy does water squirt out around the nozzel
Inside the nozzel, where the tip locks in, there is a groove for an o-ring. If that o-ring is missing, water will leak around the tip as you describe. Sometimes when the tip isn't fully seated in the nozzel and you pull the trigger, the tip goes flying out. The o-ring will fly out also. Most people find the tip but never see the o-ring. The o-ring is usually carried by any company or store that carries pressure washers.
Jan 20, 2013 | Garden
Black and decker electric power washer nothing coming out of wand all water coming out trigger.
Either the pressure tip or wand are blocked or the valve in the trigger is broken. Remove the high pressure tip and either try another tip or pull the trigger without a tip on the wand to see if you have the same problem. If available, try another pressure gun on the hose.
Jul 25, 2012 | Garden
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
New Troy-Bilt 3000 psi - Very Hard to Hot Start
When you run the unit and shut if off, release the pressure from the spray wand before trying to restart the engine. This built up pressure will cause it to be very hard to start as you have found out. If it does not start on the second pull release the pressure again. Another option is do do what I did on mine. I simply put a pull tie on the handle so I can pull the trigger back and use the pull tie to hold the trigger open. Make sure if you do this, that you remove the high pressure orifice from the end of the wand before attempting to start the engine. Otherwise the pressure will come on abruptly and could injure you or do property damage.
Apr 25, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Power washer loses pressure. Engine runs fine. Taking the nozzel off, squeezing the trigger, and then putting the nozzel back on sometimes remedies the problem. How do I fix it? Thank you.
Your bypass valve is jamming. All you do is take it out, put a smear of o ring grease around the o rings then put back in, make sure you push it all the way in and should fix the problem.
Sep 29, 2009 | Karcher 2500 PSI Pressure Washer
Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
When garden hose is connected to the pressure washer no water comes out of the wand, engine is off.
Dear radcongirl,
Try removing the high pressure hose from the machine. Then connect the water hose and see if water comes out of the outlet.( you can also try this by putting on the machine for a few seconds). If water comes out of the outlet, then you have a problem in the high pressure hose or the wand and trigger. Check also the lance and nozzel for blockage.
I do not know what kind or model of machine you have, but most machines the water always comes out of the outlet when water is fed to the inlet. In bigger machines this cannot happen because they have a reserve tank.
Regards,
Fulltech.
Jul 16, 2009 | Honda Maxus Pressure Washer MX5222
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
498 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
