Question about Dyson Vacuums
My dyson dc25 brush bar will spin for a few seconds and then stops. What can I do to repair myself? The brush bar is not jammed, it spins freely by hand.
    New Friend:
  • 21 Answers
Hi. It sounds like the lower wiring Loom is about to break. The copper wires are touching intermittently causing it to start/stop. You will need to replace the lower wiring Loom and yoke. It’s not an easy fix if you don’t know how to do it.
Posted on Feb 03, 2018
  • 944 Answers
If it spins freely no resistance you probably need a belt..
http://www.vacuum-direct.com/dyson-dc25-drive-belt.aspx
if the belt is ok then the gears may have striped ck amazon for a head assembly complete.
Posted on Jan 28, 2018
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
  • 83 Answers
SOURCE: beater brush won't spin but belt is intact and ok.
For your beater brush to spin, you have to meet two conditions:
1) the vacuum cleaner has to be reclined (put your foot on the front and pull back on the handle).
2) The clutch actuator (the dial where you switch between BEAR FLOORS and CARPETS needs to be set to CARPETS).
If the brushbar/beater bar still doesn't spin after that, call the Dyson helpline, they will assist you. If you are saying that the brushbar isn't spinning because it is not picking up any dirt, you may have a loose internal hose, a blockage in the machine or the bristles on the brushbar are worn. Call the Dyson helpline for assistance.
Posted on Jul 30, 2009
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Posted on Sep 08, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    The brushes do not spin. Nothing caught in the brushes.
    Hi, it's Jack at Dyson.
    DC25 doesn't use a conventional, user-replaceable belt. Instead it it uses a belt engineered to last the lifetime of the vacuum in normal use, protected by a sensor which shuts off the brush bar if something jams it.
    Normally, checking the cleaner head for obstructions and removing any threads or hair from the brush bar and endcap will allow you to reset your machine:
    However if you've already followed each of the steps shown in our video guide without success, you may need a replacement cleaner head or a repair of your machine. If you can contact us directly we should be able to arrange this for you, and can also confirm if this is covered under your Dyson warranty.
    When you have your DC25 easily to hand, please get in touch with the Dyson Customer Helpline so we can help determine if a repair or replacement part is needed. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    We'll look forward to speaking with you.
    Mar 09, 2015 | Dyson DC25 Vacuum
    My dc25 brush will not spin when i clean the floor
    Hi Raymond, it's Jack at Dyson.
    Like many Dyson vacuums, DC25's cleaner head includes a sensor which shuts of the brush bar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from around the brush bar and endcap, you should be able to reset the machine as shown in our video guide below:
    The brush bar will never rotate when the machine is standing upright, so make sure you recline it into the normal vacuuming position before testing it. Once it's reassembled, plug it in, turn it on, recline it and press the silver brush control switch (next to the red on/off switch) twice.
    If you'd like some further help after giving this a try, you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or a replacement part is needed, we can also confirm if your machine is within the Dyson guarantee period.
    Feb 26, 2015 | Dyson DC25 All Floors Bagless Upright...
    My dyson dc25 brush is not spinning what is the problem
    Hi there, it's Jack at Dyson.
    DC25's brush bar is engineered to shut off for protection if something jams it. Once you've checked the cleaner head for any obstructions, and removed any threads or hair from around the brush bar, you should be able to reset your machine as shown in the video guide:
    Please note, the brush bar will never rotate when the machine is standing upright. Make sure you recline your DC25 into the normal vacuuming position before testing it.
    I'm confident this will resolve the issue, but if you do need further help, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Sep 27, 2014 | Dyson DC25 All Floors Bagless Upright...
    Brush bar won't spin. Both filters have been cleaned ,all hoses checked for blockages,brush bar removed for cleaning
    Apr 06, 2014 | Dyson Dc 25 Animal
    Dyson DC25 Broken Brush Bar Connector
    Hi Alex, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC25. If the drive spindle of your machine has broken in use, you would need to replace the cleaner head assembly.
    Please get in touch with us directly, as our experts will be able to take some further details to confirm if we're able to replace this for you under the terms of our 5-year warranty. You can reach us by emailing askdysonUS@dyson.com
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    May 19, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    Vacuums Logo
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
