Question about Hotpoint Ultima WF860 Front Load Washer
Lifter broken on Hotpoint BHWM129 - replacement on order but need to get the old one out Hotpoint says its easy to do but I am stuck - its a twelve hole lifter and I cant find out how to release the cracked one?
Push a screwdriver into the 3rd hole and this will depress the tab on the drum that stops the lifter from moving towrds you. Once the tab is bent down a wee bit the lifter should slide forward and come out. To replace a new lifter the tab needs to be bent back up a wee bit say 3mm proud of the drum and push the new lifter back in until you hear a snap. That's it.
Posted on Aug 04, 2009
  • Hotpoint Master
  • 3,463 Answers
Grasp it firmly with both hands, and pull it towards you, it requires quite a bit of effort to do this.
Fit new one by pushing it in and towards rear of drum until you feel it click into place..
Please rate my solution.
Thanks.
Posted on Jul 31, 2009
Can i replace the drum paddle lifter on hotpoint wmd960, one of mine has a hole in the side of it!
You can indeed, part number for a new lifter is 1604464 and is aprox 11-15pounds.
just basically slide the old lifter towards you( bit of force) and it will come off.
line the new one up to the holes and slide back into posistion
May 23, 2012 | Hotpoint Washing Machines
Lights flashing on Hotpoint BHWM129
I had a similar problem with my Hotpoint BHWM 129 washing machine. The washer would not spin or drain properly and all the lights flashed after a wash cycle.
The solution was to pull the washer out and UNBLOCK the drain pipe which was crushed AND filled with 'gunk'. Once the crushed pipe was massaged back to normal size and the gunk was removed my problem was fixed. Not a nice job but I was going to ring HOTPOINT at £125 a call out fee so I am happy. I hope this helps someone else in time.
Apr 30, 2012 | Hotpoint Washing Machines
Hotpoint WF240P on off button stuck in.
If indeed the board is broken, then the price reflects what would be Hopoint's charge, as there repair charge is nearly £100.oo plus the board at approx£80.00.
If it is under 5 years old, then you should be able to claim under the 5 year parts cover.You could fit it your self, as it is a straghtforward repair.
If you need any more info, e-mail me.
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint BHWM129. Cannot change brushes.
there are no brushes in that kind of motor
Aug 16, 2009 | Washing Machines
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
377 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
