Question about DISH Network IR Remote Control
The sat button stays lit on my remote - DISH Network IR Remote Control
  • 374 Answers
Check the button and make sure it is not hung up in the remote such as pressed iin crooked. If this is not the case you need a new remote. Thanks for using Fix Ya.
Posted on Aug 15, 2009
SAT light stays lit but no functionality.new batts, still nothing. reset DVR, still nothing
beavs72,
If the Sat button stays lite with no function to control the receiver, either the Sat button is stuck or the remote has gone bad, especially if you already changed the batteries. You can call 1-800-333-3474, speak with Tech Support and if needed, they can send a new remote. I hope this helps.
Ray Calo
DISH Network
May 11, 2010 | DISH Network 721 DVR Remote Control
Sat button on remote stays lit and it won't let me do anything in just stays lit. I have even changed the batteries
jsblondie316
If the light stays on and you have already replaced the batteries, then the remote needs to be replaced. Please call 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Jan 14, 2010 | DISH Network 142923 Remote Control
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
I hope that helps.
Nov 11, 2009 | Innovage Jumbo Remote Control
Cannot get our jumbo remote to operate our satellite receiver which is a Direct TV. Tried all 17 codes.
Unfortunately, this model does not have a learning function, so if it doesn't know the code for a newer product, it cannot be taught. I recommend trying the auto-search function for both CABLE and SAT to see if it can control your Direct TV box.
I hope that helps.
Nov 10, 2009 | Innovage Jumbo Remote Control
I need codes to program direct tv satelite
Direct TV codes are not provided with the Innovage Jumbo Remote, but it is possible the codes for another box will work. I recommend using the auto-search function for both CABLE and SAT.
I hope that helps.
Unable to find code for time warner cable on the innovage Jumbo universal remote
I recommend using the code-search function of the Innovage Jumbo Remote for both CABLE and SAT to try and find the one that works with your Time-Warner cable box.
I hope that helps.
Nov 03, 2009 | Innovage Jumbo Remote Control
My dad has an insignia tv with AT&T u-verse cable. How do we get the remote to work?
Your best bet is to use the auto-search function for both the TV and the cable box.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program for the cable box, I recommend search both the CABLE and the SAT code lists using the steps above, but substituting the CABLE or SAT button for the TV button.
I hope that helps.
Jul 13, 2009 | Innovage Jumbo Remote Control
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
DISH Network IR Remote Control Logo
350 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
