Question about Makita DPC8112 16" 81CC Gas Powered Power Cutter Circular Saw
I am trying to rebuild the 2 stroke engine from a makita disc cutter DPC 6410, does anybody know where i can get a big end bearing or complete crank, makita are asking for extorunate prices?
  • jonwade999 Jul 30, 2009
    Hello, unfortunately the old bearing was broken up, does anyone have any ideas?
  • Anonymous Mar 18, 2014
    How do I adjust the carburettor on my Makita DPC 6200 saw
    Sergeant:
  • 384 Answers
Have you checked with a Bearing House for a repacement bearing?
Posted on Jul 30, 2009
Ive got a Makita concrete saw DPC 7311,it says a mix of 100:1 but thats alot ?
The manual says to mix it 100:1 if using Makita high performance oil or 50:1 using regular Makita 2 stroke oil. I'd go 50:1 with non Makita oil too.
Here is a site to download a pdf manual if you need it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 18, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
HI, I HAVE A HONDA CB125 TDE SUPERDREAM 87, BIG END LOOSE
I think honda only sells the complete crank as you have been told.
An expert engine machinist may be able to dissasemble the crank rebuild the journals, grind, source oversize\undersize bearings, refit bearings, reassemble and balance, but the time and cost would be more than a crank.
You may chase a second hand one from a bike breaker, personally I would try to find another motor, as if the big end has gone, there will be wear in other areas of the motor, like the cam bearings which also are not replaceable. It must have had an oil problem..
Jun 19, 2010 | 2001 Honda CB 125 T
I used my dpc 6410 64 cc saw all day cutting pavers and seemed like my blade was bent , we called it a day n came back the next morning to find the blade was straight ... am i goin crazy er did it do that...
Make sure that the blade is on correctly. If there is something stuck between the blade and the mount it will make everything off. Or if the but holding the blade on is not on tight enough you will have the same issue.
May 29, 2010 | Makita DPC6410 64cc 12" Power Cutter
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
Makita DPC 6410 won't start
Piston and cylinder kit Bailey's about $190.00
http://www.baileysonline.com/itemdetail.asp?item=DM+038130030&catID=395
HTH
Lou
This saw can handle up to 79CCs. we can rebuild him ,bigger, faster, LOL HTH
Lou
Sometimes the cylinder can be salvaged with muratic acid. Piston kits are quite reasonable.
Oct 23, 2009 | Makita DPC6410 64cc 12" Power Cutter
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
Makita DPC8112 16" 81CC Gas Powered Power Cutter Circular Saw Logo
194 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
