Question about Sony KV-27S42 27" TV
Tv wont turn on
This morning before i left for work it was like automatically channel surfing, so i turned it off even shut down thw power and when i got home it won't even power back up, checked the fuse but its good, don't know whatelse to do, help?!
  • 27 Answers
Try to plug in again...if there's no reaction at all, then the power suply section may checked...(I.C. regulator str.... followed the horizontal output transistor or some of the zener diodes regulator or broken PCB line
Posted on Jul 30, 2009
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
What makes my Sanyo DP32746 shut off when I press channel up button?
Main system control memory IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2014 | Televison & Video
Why wont my 47" westinghouse tv ld-4655vx turn on?
Just fixed this problem and I made a video showing how I troubleshot and repaired it.
Apr 30, 2014 | Westinghouse Televison & Video
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Sony TV shuts off automatically
1.Check first if the shutdown of your tv follows a certain period of time. Example after using it within 12 hours it automatically shut down. If so the the matter is only on settings of your tv.
2.But if your tv shut down at an irregular time the problem is in your board. In this case if your tv still work but still shutting down automatically its better not to use it so that their will be broader damage.
3.The most common defect on this case is loss contact of components due heat and mechanical undergone during the usage of the tv. If you know how to resolder board, try to resolder the components specially those who are showing loss contact. You can recognize it because a good solder one has shinny and no round like on the soldered surface.Try also to resolder important parts such as IC's and transistors. note : a good resolder needs to be done in order to avoid problems and damage.
4.Another possible cause is the tack switch for channels,menu,power and etc. You can remedy it by spraying it a contact cleaner.
5.If the problem still going even after the procedure its better to bring it on reliable and trusted service center.
Jul 11, 2009 | Sony Televison & Video
Both TiVo and Vizio remote aren't working right. Has to be TV.
my remote is not responding to new battery not showing green light.
Nov 16, 2008 | Vizio L32 32 in. LCD HDTV
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Sony KV-27S42 27" TV Logo
180 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
