Question about Dometic RM2193 Compact Refrigerator With Ice Box
Our Dometic RM2193 cools on gas but does not work on electric
Our Dometic RM2193 cools on gas but does not work on 120 electric. Not sure which fuse to look at. Electric plug in back runs on other things.Back of refrig gets hot on gas, but does not when on electric. Camper is level.
    President:
  • 704 Answers
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Posted on Jul 30, 2009
Rm2193 dometic fridge Works with gas but not on 120 how do i fix this?
Anon, Check the attached links,instruction and guides to diagnose fridge, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RV Refrigerator Repair 101 How To Diagnose Problems With RV Refrigerators...
The RV Forum Community
RV motorhome and bus conversion mechanic resource
Aug 03, 2016 | Dometic Refrigerators
Dometic RM2193
well the flame must not be correct...make sure the burner is pushed up in the flu properly.....if the element does not get the correct heat it will not work properly.
Jul 26, 2010 | Dometic RM2193 Compact Refrigerator With...
I use a Dometic RM2193 in my pop-up camper. Can anyone tell me what temperature differential I should be able to acheive on 120VAC, propane and 12VDC? On 120VAC I was getting about a 40 degree fairenheit...
Usually from the Bottom of the refrigerator you should have minimum of 43f or colder than ambient. Should work very close to same on both gas and 110, on Dc it may not cool as good. From your description you may have an issue with ventilation. Cold air needs to flow in through the lower vent and out through the upper, if it cant, cooling efficiency is lost. Adding a fan kit can help on hot days. On gas you may have particles that fell down in the burner. Just take the cover off, take the burner screw out and blow down into burner to clean out. compressor or canned air works fine. If cleaning the burner doesn't improve it enough on gas to match electric you have to make sure your regulator on your rv has enough pressure... the fridges require 11 inches of water column.
May 03, 2017 | Dometic RM2193 Compact Refrigerator With...
Dometic rm2193 will only cool to 50 Electric and gas is ok
Do you mean it runs OK on gas ?
If so you probably need an element.
If not , you need a new sealed system
Aug 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Works on 120V, but not on gaz. I succeded in cleaning the burner jet and I get a flame. It ligth well now but the flame very small. The frig doesn't cool. Help ?
These fridges require that the control switches be in the correct position for the power source you want to use. If you try to operate the fridge on gas and have the electric 120V-AC switch on, all you'll get is the gas pilot light to stay lit. Also, when running on gas, the electric has to be off.
Here's a link to the manual for your unit. Print a copy and save an electronic one for future use, in case you lose your printout.
Hope having the manual helps you to get the fridge working on all the power sources you need! Best regards!
Jul 03, 2009 | Dometic RM2193 Compact Refrigerator With...
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic RM2193 Compact Refrigerator With Ice Box Logo
1,098 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
