Question about Brother MFC 210C All-In-One InkJet Printer
Printer problem I have just changed the black cartridge in this printer and printer will not print. It went through the cleaning process already
  • 832 Answers
Did you check the right placing of the ink cart? Is the support locked above the cart top?
After checking press menue then start mono (blue copy button). then fourtimes arrow-up button. machine will display maintenance and blicking. press 7 then 6 then 4. machine will be initialize the carts. press start mono (blue copy). machine will initialize the carts and will run some cleaning. After maintenance is shown again leave this mode by pressing 9 then 9. Do a test print.
If you cant see any bk insert another brand new cart and do the procedure again.
If trhere is still no bk the print head is clogged (because of generic ink??) and cant be cleaned any more! The ph has to be replaced by service personal!
Posted on Nov 24, 2007
I have installed a new ink cartridge and gone through the cleaning process serval times but I can not get anything to print in black. If a document is in all black, all I get is a blank sheet. If I change...
The first thing to check would be your print utility. Make sure that it is aware that there is a black cartridge installed. If you've gone through the cleaning process, try printing a test page and see if that will print the black. If not, it is either a setting in your utility telling it not to print in black and white, or a hardware issue with your printer. I will look up some documentation for your make and model printer to see what else the problem might be. Please advise with any changes when you check the print utility.
Nov 05, 2011 | Brother MFC-5860CN InkJet Printer
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
Black Ink Problem
try cleaning print head and nozzles and align the Print Head. If nothing the problem may be with your printer itself
Jun 13, 2010 | Brother MFC-465CN InkJet Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Printing in color
Since you already tried cleaning tha colored cartridges the next thing that you can possible do is to remove all the cartridges then turn off the printer for 5 minutes then put the cartridges back in and hopefully now the printer will be able to recognize that cartridges are still not epty, but if still the same thing try to use another colored cartridges if possible so we can check if that will also give the saem results...
Hope that helps.......
Oct 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer won't work
Norma930,
Try cleaning the Print Head (a function you should find within your printers properties). Don't do it if you have already done so since replacing the cartridge as the process uses quite a bit of ink.
Good luck.
Mar 18, 2008 | Computers & Internet
Brother MFC 210C All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
