Question about Dryers
My Roper Dryer keeping running.
The timing does not work. It does not stop drying. What part do I need?
    Problem Solver:
  • 15 Answers
Stuck Timer. Replace Timer.
Posted on Jul 30, 2009
Roper dryer doesn't stop
Hi frank_kleins...
Sounds like your timer is faulty...replace, they are not rebuildable.
When you go to replace the timer, be sure to buy the same kind, and remove one wire at a time and replace one wire at a time that way you will not get confused with the replacement
Please rate me
Bud
Sep 28, 2012 | Roper RES7648E Dryer
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Roper elec dryer starts and runs for 10 sec then stops runnning
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Roper RES7646KQ Electric Dryer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer model # RED4405Q shutting off
The motor may be getting hot due to bad rolers idler or glide. You need to take the machine apart and oil it. While you have it broken down you may want to turn the motor and see if it is stiff. The motor can be oiled but it is tricky. there are no oil ports you must make some. I use zoomspout oiler from ace hardware. Its high temp resistant formula and viscosity is perfect for dryers and HVAC needs.
75ddae3.jpgI have various essays on accessing these machines and diagnosis HERE
Mar 02, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
