Question about Dyson Vacuums
I have a Dyson dc08 it won't turn on. No smell just won't turn on. Can someone help me? I need to know how to test for... If it's the switch ? If it is the motor ? Motor brush? Cord to machine? Please help the repair man going to charge at learnt $80/hr and any parts on top of that so I want to do this myself.
    New Friend:
  • 26 Answers
Most likely to be the motor. Assuming you have checked the fuse. It could be the cable but a DC08 is an old machine and it is likely that the motor will have died. It’s replaceable for around £65 (motor)
Posted on Feb 03, 2018
  • Dyson Master
  • 1,570 Answers
Start by testing the cord and switch to be sure you are getting proper electrical voltage. If so check at the motor. If you are getting proper voltage to the motor and it won't run you may need a new motor.
If you are not experienced in doing the testing required to determine the source and cause of problem or problems it may be less expensive and a lot safer to hire a professional. Not all vacuum repair shops can repair Dyson vacuums. I highly recommend a repair shop that is a Riccar Warranty center as they have the proper training to do the repair correctly.
Posted on Jan 29, 2018
5 Suggested Answers
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: DYSON MOTOR BRUSHES
how do I change the carbon brushes in a dc07, I have removed the brush units from the motor
Posted on Jan 18, 2009
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Posted on Jun 01, 2009
Vacuum Guru
  • 78 Answers
SOURCE: how do i change the motor on th dc08 dyson vacuum
Hi there, It is a bit difficult to describe how to change the motor for a Dyson DC08 so I have made a video. I think it shows how it's done pretty clearly if you like the video leave me a thumbs up or a comment. If you realise while watching that you need parts for your dyson I would recommend you check out Nelson Vacuums or Vacuumspot.
Posted on Dec 07, 2010
WHAT MODEL IS SERIAL NUMBER 151-UK-A32802
Hi there Michelle, it's Jack at Dyson.
From the serial number you've provided, your Dyson vacuum is a DC08 T Allergy cylinder. You can find support for this model on our website: http://www.dyson.co.uk/support/dc08tw/dc08-telescope-wrap-allergy
Please note, spares and accessories for DC08 T will differ to the spares and accessories for the standard DC08 model. Floor tools, accessories and other parts for DC08 will not fit DC08 T, and vice versa.
If you'd like further help with your machine you're welcome to give the Dyson UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Mar 10, 2015 | Dyson Vacuums
Can you replace dyson on/off switch dc05 turbobrush
There are a number of places that list replacement switches. There are also a number of DC05 models, though the power switch is not likely to vary across them. Amazon, for instance, has a Dyson Switch for models including the DC05 and six other models (see here
Dyson Switch Dc03 Dc04 Dc05 Dc07 Dc08 Dc11 Dc14 On Off )
This video (ostensibly for a DC08, but the procedure should be pretty much identical) shows how to take the unit apart, get at and test the on/off switch, and replace it if need-be.
How To Change Dyson DC08 Switch An Easy To Follow Tutorial
Good Luck!
Jul 31, 2014 | Dyson DC05 Cylinder Bagless Canister...
My vacuum was making a funny noise and had a bad smell
Hi John, it's Jack at Dyson.
Most Dyson vacuums include a thermal cutout which shuts the machine down for protection if it starts to overhead. You should find it will run again after it's cooled down for around 2 hours.
This is likely to have been caused by a blockage, or because the filter is overdue for a wash. To prevent this from happening again, please follow the steps shown in our Support guide: http://www.dyson.co.uk/support/dc08/dc08-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/check-the-floor-tool
In normal use, the filter needs to be washed at least once every 3-6 months, as shown in the video attached. Use cold water without detergent, and allow at least 12 hours for both sections of the filter to dry completely before replacing it.
If you'd like some further help from our experts after you've given both of these steps a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), or 01-475-7109 (IE).
Jan 28, 2014 | Dyson DC08 Cylinder Bagless Canister...
Dyson dc08 not turning on
you can go to: http://www.dyson.com/support/help.asp?article=51&product=DC22-MOTORHEAD-US, this a section for troubleshooting for dyson.
You must clena any clogged from hose, bag.or blockage, Clean the filter. In most time, the machine has a thermic switch or thermal fuse, Inspect or test and replace or reset.
God bless you
Jul 15, 2012 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
There was a fluttering noise in the main engine base that could not be shaken out and then the fluttering got worse after the 3rd use and then there was a slight burning smell and now the 08origin...
I'm sorry to hear you're having difficulties with your DC08. Due to the nature of the problem you've described, it's probably best if you get in touch with us directly so we can assist you in resolving it as quickly as possible.
You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Sep 25, 2011 | Dyson DC08 Cylinder Bagless Canister...
I had used Dyson DC08 to **** out a wet car carpet. A few days later when using the V/C, there was a burning smell. Subsequently I washed the flexible hose, changed the pre-filter and post filter , but I...
We'd strongly recommend against using your Dyson to pick up water. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Sep 01, 2011 | Dyson DC08 Cylinder Bagless Canister...
Dyson dc08 motor made rumbling sound and stopped
Hi there SmartAlec from NelsonVacuums.com.au here. Almost certainly it is the motor gone :(. Take off the lid that is under your bin and look at the filter underneath, if it has a black underside and a kind of burnt smell you will need to put a new motor in. If you happen to live in Australia you can get a motor from NelsonVacuums.com.au here is a link to the correct page. Hope this helps.
happy Vacuuming!
May 20, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to replace motor on Dyson DC08 vac
I have made a video showing how to replace the motor on a Dyson DC08. If you follow the instructions you should be able to do it. If you find the video helpful please give me a thumbs up or a comment.
If you find you need parts for this procedure I would recommend Vacuumspot or Nelson Vacuums
Dont forget to let me know how you go!.
May 17, 2010 | Dyson DC08 Cylinder Bagless Canister...
I have a DC08 Animal. which I love, but the switch is stuck, know I can buy a new one, but HOW do I take it apart, thanks. Maggie
HI there,
I have made a video showing how to access the motor and switch of a dyson dc08.
Have a look at the video I am sure you will find it easy to follow. Please if it is helpful take a moment to give it a thumbs up or maybe leave a comment.
If you need parts for your dyson dc08 check out Nelson Vacuums or VacuumSpot.
Hope this helps!
Dec 22, 2009 | Dyson DC08 Hepa Allergy Bagless Canister...
Vacuums Logo
103 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Etronix
Level 1 Expert
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
