Question about Frigidaire FRS26KW3AW Side by Side Refrigerator
I have a FRS26KW3A Frigidaire. Noise with Ice Maker
There is an ice build up when you remove the ice cube tray holder and an annoying noise. This noise does stop occassionally but the noise is there more than not.
  • 109 Answers
SOURCE: Roper top freezer ice maker out of sync? Too warm?
sorry you must replace the icemaker.
Posted on Mar 30, 2008
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
The ice maker is making a slight clicking noise and not dumping ice. why?
it sound as the tray should be look into. It can be worn out or crackrd
Jul 03, 2014 | Jenn-Air JCD2389G Side by Side...
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Feb 08, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker won't dump cubes
the problem is that the tray doesn't eject the cubes, they get stuck and it just breaks them and only parts come out instead of the whole cube/crescent, then the proper amount of water comes in as refill, the tray gets too full and your problem begins. Take the unit out, then take the tray out, its's easy, and give it a light coat of Pam, olive oil or corn oil, the cubes will eject properly. It took me 3 years to figure this out, it willl amaze you.
for everyone with the fan screech noise, replace the fan motor, don't buy the blade, look around the websites, I found it, my second replacement, for 28 but as high as 65.
yeah I hate this fridge too
Feb 08, 2009 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Icemaker noise and malfunction
on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
Feb 19, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice Maker Making Noise
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
Ice build up on fan
problem is most likely caused by water overflowing from ice tray and then freezing to motor, hold light switch in and see what happens when tray fills up. Regards Advisor
Feb 08, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire FRS26KW3AW Side by Side Refrigerator Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
