Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Lawn mower wont stay running only five mintues at a time it like it gets hot fast and then turns off
    Scholar:
  • 45 Answers
Check the Float bowl assembly.
Below the carburetor, there is a rounded metal object about 3 inches in diameter. Find the hex nut at the center-bottom of the bowl and unscrew it.
Pull the bowl off, being careful not to twist the float which hangs from the carb. Clean it out well, check the gasket for good seal and replace.
Then check the priming bulb, that round flexible thing you press on to prime, and make sure it is not torn.
Lastly, Try running the mower without the air cleaner for awhile. If it runs good that way, you need a new air cleaner element.
Posted on Jul 30, 2009
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
It starts and runs but gets hot and quits
the only way for an air cooled motor to get hot is from the cooling fins on the head and cylinder to be blocked from straw and mud
remove the cowl on the motor over the fly wheel and clean it all out
Nov 07, 2015 | Briggs & Stratton Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
My lawn mower will start, but wont stay on. What ...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 20, 2010 | Mtd 22" White Outdoor Self Propelled High...
Bilt 5.5hp Self Propelled Mower: Lawn mower will not stay running...
they were in/out.
May 18, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Hotpoint dryer wont stay on
is the drum spinning easy ?with no metal to metal grinding sound ? could be the start run capacitor for the motor its black/ round and is on the side of motor //or the motor windings have overheated 2 manny times an swelled the windings ///the drum shaft sleave/bearing could be wore out or gone //the front drum slides could be wore out or gone //kinda need a little more info.. hope this helps.. let me know., an good luck
Mar 23, 2010 | Hotpoint NLL113EYWO Electric Dryer
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
562 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
