Question about Canon DC100 DVD Camcorder
No volume on canon DC100
Just started using my canon DC100 camcorder and notice on playback that there is no volume. Been through the manual, it states on system setup there should be a volume setting but there isn't. please help, sons birthday party tomorrow and i need the camcorder
thank you
  • 537 Answers
Re: no volume on canon DC100
Look on page 29 of your manual
Are you sure you do don't have the system muted?
Press the Menu, then System Setup, press SET. Select VOLUME then press SET.Adjust the volume with the left/right arrow keys, then click set.
Hope this helps...
If you don't have the manual (although I know you said you read the manual), go to:
Posted on Nov 24, 2007
0 characters
3 Points
How do you turn the volume up?
Do you mean playback on the camcorder, or playback via a TV or PC ? If on the camcorder, there may be a menu setting for this - check the manual. If TV or PC, use the volume control on that.
Alternatively, there may be a menu setting to permit you to record at a higher volume. Be careful if you choose this, as background noise will also increase in volume.
Mar 10, 2016 | Canon Video Cameras
Canon dc100 will not finalize memorex disc, which says it can be used in canon
make sure the power adapter is connected, you can not finalize on battery power alone. also make sure you are in playback will say original in the top left corner..then you should be able to finalize when you go into the menu
Apr 10, 2010 | Canon DC100 DVD Camcorder
How do i put my camera in the still frame mode?
follow this link to your manual
1 open cover and move slider down to C
2 press the stop start half way
once auto focus is adjusted O will turn green and 1 or seveal af frame will apear.
3 press start stop fully
the DISC access indicator will flash as image is being recorded.
Nov 15, 2009 | Canon DC100 DVD Camcorder
No manual in english
Please click Canon Support to download user manual of DC100 in English.
Feb 10, 2009 | Canon DC100 DVD Camcorder
Feb 10, 2009 | Canon MV960 Mini DV Digital Camcorder
Lost instrutions whilst movin home/require info on how to use it
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 30, 2008 | Canon DC210 DVD Camcorder
Manual for dc100
Jul 03, 2008 | Canon DC100 DVD Camcorder
Turning off disc info on playback
Oct 23, 2007 | Canon DC100 DVD Camcorder
Instruction manual
i had the same problem. you may have plugged your power supply into the a/v slot near the function button..that is what i did. there is another place near the lens to plug it in. try that and then finalize should be an option.
Aug 13, 2007 | Canon DC100 DVD Camcorder
Finalzing my disc
you can only finalize a disc in the dc100 with the power adapter on. (page 59 instruction manual)
Aug 01, 2007 | Canon DC100 DVD Camcorder
Canon DC100 DVD Camcorder Logo
138 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
