Question about TT Systems BE-142FRS 2-Way Radio
One BE-1438Sp 2-way FRS transmits, one squeals
I have a pair of Bell (TTSystems) BE-1438Sp 2-way FRS radios. One came up lame last week: it makes a squealing sound as a microphone has feedback through speakers. Also, the voice transmission never makes it to the other receiver. It can, however, monitor the other radio perfectly. Batteries are fresh. Channels are identical, all settings are the same.
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
COBRA MICRO TALK1 FRS 100
THEY SHOULD ALL WORK TOGETHER ON THE FRS FREQUENCIES. MAKE SURE THAT YOU SET THE CHANNELS AND SUBCHANNELS TO THE SAME ON ALL FRS RADIO.
Oct 07, 2012 | Cobra Frs-120 Microtalk 2-mile 14-channel...
How does the Mickey mouse fm wireless microphone work
my microphone had no "applause" button. i flipped the switch on and turned radio on. put microphone up to radio speaker. I pressed/waited auto scan button on the radio until I got the "feedback" squeal. no adjustment necessary.
Dec 30, 2011 | Toys
What is the distance range capable of this radio: Bell Pones by Northwestern Bell Phones Model #99141
FRS/GMRS radios operate in a frequency range that is strictly line-of-sight. That is, if you cannot see the party holding the other radio, you cannot communicate with him. No matter what a manufacturer claims, the effective range of these radios, under most circumstances, is 1/2 mile or less.
Bill B
Aug 18, 2010 | Northwestern Bell 99141 2-Way Radio
I cant finde a replacmet internal microphone for my talkabout 250
They don't have one, sorry. The radios are so cheap that they stopped making parts for them.
Jul 14, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Sqeal when talk button is pushed
Two known causes of squealing when the radio is put under a load (such as when the PTT is pressed) are a low or bad battery, or being too close to another radio.
Apr 21, 2009 | Audiovox 2-Way 14 channel FRS Family Radio...
Only one walkie talkie produces sound
Check for Squelch Codes you can see on the display channel number and sub chanel number this is the squelch code
Both displays must show the same icons
If both are the same, try with and audio accesorie, if works may be your speaker is broken.
Dec 23, 2008 | Bell BE1400FRS (14 Channels) 2-Way Radio
Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Aug 14, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
2-way radios
The Bellsouth 2231 is a FRS VHF I couldnĀ“t find if thi Bell south 1007 is FRS in UHF or VHF if you have this informtion compair them if both are in the same band VHF or UHF both radios can communicate to each other
Mar 02, 2007 | BellSouth 1061 (14 Channels) 2-Way Radio
TT Systems BE-142FRS 2-Way Radio Logo
153 people viewed this question
Top TT Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a TT Systems Radio Communication Expert? Answer questions, earn points and help others
