Question about Avaya Corded Phone avaparp18d
I need to reset the time on the phone display. I need to reset Voice mails for extensions of prior employess.
  • sbeauch Jul 30, 2009
    Partner Voice Messaging.
Change time on Partner Phone system
What voicemail do you have?
Partner mail VS?
Partner Messaging?
Partner voice messaging?
Posted on Jul 30, 2009
  • Anonymous Aug 05, 2009
    Dial into vociemail, when prompted for the extension number, enter "0" followed by the "#" sign
    enter the password, default is 1234 followed by "#"
    I think it is option 6 or 7
    BUT, you will need to know the mailbox number associated with the extension
I can't log into my Nortel vm account
Change the administrator password by pressing Feature 985 dial 9 even though it is not listed as an option. The display will show Pswd: dial 73738767793. The display will show Reset pswd? Press YES. Now you can log into the voice mail system administrator using Feature 983 and the password 1020000 if you have 3 digit extension numbers. Add or delete the 0 between the 1 & 2 depending if you have 2 digit or 4 digit extension numbers.
Sep 17, 2012 | Nortel Networks T7316E Telephone Platinum...
Need to reset nec phone
Easiest way to reset the phone is to unplug it then plug it back in. If you are talking about resetting the voicemail associated with the phone extension, that's a little more involved.If you need the voice mail reset, you need to have the voice mail administrator (typically the receptionist) go into his/her voice mail and choose the MGR option if using the display "softkeys" and follow the prompts to reset the users security code or voice mail acct. If softkeys aren't available, follow the voice prompts to "system manager" and either delete the security code or reset the extensions voice mail entirely.
Jan 19, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
Unlock Nortel t7316e voice mail. when i try to get into my voice mail and after entering my password, th ephone displays "mail box locked contact admin. i am admin and do not how to unlock. I have...
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
Mar 15, 2011 | Nortel T7316E 2-Line Corded Phone
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
DKT2020-SD Msg Light Blinking for no reason
#409 to cancel receive message...may need to key in few time to cancel few message
#64+sent messane extn - to cancel sent message
Apr 17, 2009 | Toshiba DKT2020SD Phone
How to get to message without knowing the prior code
I found out that if you have extension 850, set up as the voice mail you can do the following: dial 850, then hit * when the automated operator comes on. Put in your extension only at first, then when it asks for the access code punch in the extension AND 997 (six digit number) and then the # sign. This should put you into the voice mail setup.
Feb 24, 2009 | Toshiba DKT-2020 Corded Phone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Inter-Tel Axxes phone outside calls don't go to voice mail
I had this same challenge with an InterTel 5000 system. Outside calls going right to the receptionist. My solution: You cannot fix this from a phone, you must open the DB Session Manager, move to Call Routing Tables (this is right above Voice Processor) and move all of your extensions above the "NO MATCH" and "EMPTY" lines on the bottom. Anything below those two lines will bypass the extension and go straight to the main attendant. At least in my configuration it does. See below...
bb752dc.jpg By just moving that last extension "5059" above the "NO MATCH" line, calls will now go to the extension from an outside caller. The trick is to hold your mouse on the pen icon and click several times to activate that line, then you can drag it to where you want. See below...
8e5e1dd.jpg Hope this helps someone?
vandata1
Sep 27, 2007 | Inter-Tel Axxess Corded Phone
Avaya Corded Phone avaparp18d Logo
302 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
