My dryer seems to be getting too hot. The back of the machine gets too hot to touch and the clothes that come out of the dryer are EXTREMELY hot. I'm afraid that it is a fire hazard. Any repair or checks that I could do before calling a repairman?
-   my whirlpool dryer gets so hot inside that my clothes come out smelling burnt. Even on the low setting after 2 minutes of running the metal grate in the back is too hot to touch and have actually burnt my fingers. Forget about putting sinthentic clothes in cuz the actually burn. Is there something wrong with my drier. My service guy says that is normal but when your clothes burn on the low setting what am I supposed to do?-   Guest
Dec 11, 2007
-   dryer is very hot to the touch.also noticed char mark in middle of the back of the dryer.
Also if you touch the inside face of the drum it will give a shock... -   Guest
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Was this helpful?
Yes
No
Popular Solutions for GE DWSR405EBWW / DWSR405EBCC
Replaced heating coil but dryer still not drying clothes and a small puddle of water in right front...
(More)
Replaced heating coil but dryer still not drying clothes and a small puddle of water in right front corner appeared after running for an hour or two
We have had this dryer for about 5 years and love it. We have never used the hat dryer and we have...
(More)
We have had this dryer for about 5 years and love it. We have never used the hat dryer and we have seemed to misplace the instruction book. How do you place it in the dryer.
i was drying a pair of tennis shoes and somehow they jammed the dryer and it was unable to turn..it...
(More)
i was drying a pair of tennis shoes and somehow they jammed the dryer and it was unable to turn..it almost immediately turned off..i checked the circuit breaker and it had not tripped...so im guessing might be a fuse..but im having trouble locating where they may be.
