Question about Panasonic KX-P2023 Matrix Printer
P2023 prints garbage with vista
Even though windows vista has built-in drivers for panasonic dot-matrix printers, including the kx-p2023 printer, it prints nothing but garbage. It seems definitely to be a driver problem, as I tried all of the other panasonic dot matrix drivers, and the kx-p1695 will at least give me one line of good text printing before continuously form-feeding. The Printer is good because I still use it with my old emachines T3104 under Windows XP.
New Computer is:
Compaq Presario CQ5110Y
AMD Athlon x2 7550 Core Processor
3GB RAM
320 GB Hard Drive
Windows Vista Home Premium
Service pack 1
    President:
  • 2,306 Answers
Did you get the Vista driver for your machine from Panasonic? If not, it may not work. I use VM ware and run windows xp in virtual machine in order to use some of the older drivers.
Posted on Jul 30, 2009
I have the matrix printer Panasonic KX-P3196 and I cannot find somewhere a driver for windows vista. Do you know if there is an alternative solution? Probably an IBM driver?
Epson drivers better bet ie rx-80 if 132 char printer.
Lot of dot matrix printers had Epson compatible mode available as they were the biggest then.
Apr 26, 2010 | Panasonic KX-P3196 Matrix Printer
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
Use EPSON
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
Network printer printing rubbish when printed from Vista
The problem with dot matrix printers is that these are very old printers and you may not find a printer driver for them that run with Vista. If the incorrect printer driver is installed, the printer will print rubbish.
The only suggestion I can offer is to try various generic printer drivers until you find one that works. Connect it to the LPT1 printer port first and when you get it to work then set it up on the print server.
Also try Panasonic support and ask if they have a printer driver for this model printer that works with Vista.
Oct 22, 2009 | Panasonic Office Equipment & Supplies
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
Panasonic kx-p1121 driver
Dot matrix printers usually work with IBM compatible native drivers. I have tried similar model with Vista worked fine. You may need to perform manual installation by using LPT1 parallel port. If you cant see similar model in the list you can choose generic text printer or IBM Proprinter.
Good Luck
Nov 10, 2008 | Panasonic KX-P1131 Matrix Printer
hai
apply some oil to the rod . keep the head postion in the last. Try to print with out the ribbon catriage
thank u
Feb 04, 2008 | Panasonic KX-P2023 Matrix Printer
Panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
Nov 08, 2007 | Panasonic KX-P2023 Matrix Printer
I NEED TO GET A DISK SO I CAN ADD TO MY COMPUTER. PANASONIC KX-P2023
If your looking for the printer driver, it should already be in the computer. Windows 2000, XP and Vista all come with the KX-P2023 driver pre-loaded. If you can't find it, you can use just about any of the KX-P2000 series drivers that are pre-loaded wqith Windows.
Oct 15, 2007 | Panasonic KX-P2023 24-Pin Impact Printer
Panasonic KX-P2023 Matrix Printer Logo
389 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
