Question about Garden
I ahve a model Weedeater fl20 and the string won't come out when tapped and when I tap it by hand, the string comes out less than an inch and the spool doesn't pop back up. I'm thinking that maybe the spring is to short but I don't see any way to take the spring shaft off. Any ideas? Thanks - Ed
    President:
  • 1,714 Answers
The string gets caught and is jammed. Give the cover a quarter tun to remove it. Then, pull the spool off with the plastic cutting string. Unwind it a bit and rewind it so it's straightened out. Then feed the two ends out the holes on the side when you put it back.
Posted on Jul 30, 2009
I have a weedeater featherlight which is discontinued, but anyway where is the setscrews on the carb i need to tune it!
they are covered,if you need to tune it then you need to clean and rebuild the carb and replace gas lines,buy it all on ebay for less than 20 bucks,ethanol kills plastic,buy the whole carb,you cant adjust yours
Jul 26, 2015 | Garden
My 26cc homelite straight shaft weedeater keeps
If the guard isn't in place and cutting the string to length as it's running, it will keep feeding line out.
Sep 23, 2014 | Garden
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
Weedeater gas line
I ran a short piece of coathanger that I cut through the fuel line and used electrical tape (stretched tight) to tape it securely at the end and pushed it thru the hole. Then I removed the electrical tape and cut off the part of the hose that had been taped. You waste an inch or two of fuel line, but that's how I got mine thru. Sure hope this helps and best wishes.
Aug 26, 2009 | Garden
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Aug 25, 2009 | Garden
How do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Jun 14, 2009 | Garden
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How to replace string in a homelite trimmer
have the same weedeater, see utube vids too hard to explain with words
Jun 08, 2009 | Homelite Mighty Lite Lawn Trimmer
Water dispenser is not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
