Not sure i'm threading right. i need a how to video. also the bobbin.
The manual may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjboK34uvnYAhVT3GMKHTBhBqgQFgg0MAI&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F712_white-1740-x.pdf&usg=AOvVaw0jrJZxFJ3zHgkEjnFCqSHI
Be sure to ALWAYS RAISE the presser foot when threading the top thread.
SOURCE: I've lost my manual and video need threading info
I had the same problem. I found if you turn the wheel three times and then put in material, it will work fine. If you try to run a long thread to see if it works, the lower looper will break. Try it with material and it will work fine.
SOURCE: Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
SOURCE: won't pick up bobbin thread
machine must always be threaded with needle in up position and pressure foot raised if not thread will not pass between discs this is the cause of your problem.
mary h
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
SOURCE: I need instructions threading the bobbin on Kenmore sewing machi
I believe it is a seperate bobbin case, hold the open part of the bobbin case towards you with the finger at the top, hold the bobbin case by the latch, drop the bobbin in so it turns anti clockwise and pull the thread through the slot about 6 inches, keep hold of the latch, and pop the bobbin case in
