Question about GE WJSR2070B Top Load Washer
Agitator There is power going to my washer but when it fills the agitator is trying to move but can't.How do i get the agitator off to see if there is someting stuck under it?
  • drrxdelite41 Mar 22, 2009
    I hade the same prob."was ez to do". Now it wont agitae and will spin if I reset the spin cycle.
  • 447 Answers
Your problem is the agitator coupling is stripped. Very common on your washer. Just pull up from the base of the agitator to release it. Lip your fingers under the bottom and work it from side to side while pulling up. The coupling is the brown plastic piece attached to the transmission shaft. Remove the bolt and oring. If that bolt is rusty or oring damaged get a new one with the new coupling. Sometimes the coupler is real stuck on the shaft. Becareful not to damage the transmission shaft or the threads for the bolt to hold the coupler if you use a gear puller.
Posted on Nov 24, 2007
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore 417.97922701 washer tub will spin but will not agitate
Disconnect power to the unit.
Does the agitator move freely in both directions by hand?
Could be your agitator coupler needs to be replace
Also need to verify the lid switch and pressure switch are working properly. Let me know if you need further assistance
Nov 10, 2014 | Washing Machines
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool ultimate Care II problem
IF THE PROBLEM WITH THE AGITATOR IS THAT IT DOESNT HAVE THE POWER AS BEFORE IT SOUNDS LIKE THE AGITATOR DOGS NEED REPLACING.GOOD LUCK
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE WJSR2070B Top Load Washer Logo
292 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
