Breville ESP8XL Espresso Machine
Problem for Breville ESP8XL Espresso Machine
Trips GFI circuit brakers
By joerodriguez on Jul 30, 2009
My recently acquired ESP8XL trips GFI circuit brakers after about 30 - 40 seconds of turning on the machine (warming Up). But if I connect it to a non GFI receptacle, the machine is able to work as intended. What might be the problem?
Best Solution
posted on Jul 30, 2009
Very Helpful)
spacerook
Rank: Guide
Rating: 83%, 3 votes
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Breville ESP8XL Espresso
Questions and Unsolved Problems for Breville ESP8XL Espresso
Do you recommend Breville ESP8XL Espresso Machine?
Answer
Answer
Filters don't fit into filter holder. Can't put filter holder into place onto machine
Answer
My frother no longer functions. What should I do?
Answer
Why am I having difficulty getting a rich cup of coffee when I pack down the coffee in the filter
Answer
When I turn the dial to espresso it makes the sound that the steamer makes and no water comes out.
Answer
the little part were the cofee comes out from is clogged and the water and coffe comes out of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Breville ESP8XL Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
