Question about RCA TH1602 MP3 Player
Power Up then shuts down
My player turns on and then off right after. new batteries are in there.
  • 2,335 Answers
When my Pearl was doing the same thing, these are the steps I followed after downloading the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1
remove the battery,
start the program,
hold the play button while plugging into usb,
release the play button the the term "initializing" replaces "searching",
click the start button to replace the firmware.
You might want to try leaving the "format data" box unchecked the first time. If that doesn't work and allow you to backup your music, bite the bullet and format the data area.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Posted on Sep 18, 2009
New battery in Acer laptop shuts down computer at 44% power ?!?
In the power options at the control panel you can set the battery options there to shut down at a lower percentage. Also within the software for your battery as well. At the task menu lower right hand corner tick the battery settings. John
Apr 09, 2012 | Computers & Internet
PMP-120 Battery Discharges too quickly
Yes,
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
Player shuts off
did you use a different battery?
Mar 12, 2008 | Zenith ZPA-314 Portable DVD Player
How do I bookmark or save my place in an audio file
Try and press pause before you shut the player off.
Mar 30, 2010 | Coby MP-610 MP3 Player
I use my Sansa only during my workout. I fully charge the battery before and within 20 minutes it stops playing. The battery shows it is 3/4 full but I can't get it to play. It just shuts off!
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa e250 MP3 Player
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem .
Hi teddyabout,
There are few reasons your SanDisk Player is acting up. Here are some things to try out.
Make sure the HOLD switch is turned off before you power up your player. This will sometimes cause errors in booting.
If that doesn't work you can try a soft-reset by holding the power button down for 15 seconds then try turning the player on normally again.
Finally, if you are brave enough, you can take the battery out of the player to force a complete reset of the player and battery. This is done by taking the four screws out of the back of the player and removing the battery. After 30 seconds, put the battery back (be sure the it is seated properly) and replace the screws.
Good luck
-SHG
Jan 14, 2009 | SanDisk Sansa e200 MP3 Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
Something is wrong
sounds like a battery problem or a power problem. Best thing to do here is send back to creative or contact on line.
Apr 10, 2006 | Creative Labs MuVo Slim MP3 Player
RCA TH1602  MP3 Player Logo
29 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
