Question about AT&T Lucent MLS-12D Phone
I have an MLS-12D phone that needs odd programming - picking up the handset to call out should default to our main line (Line 1) (right now it defaults to a different line ? Line 2). Also, it should NOT be able to place outbound calls on Line 3; but it SHOULD be able to pick up calls that are ringing or on hold on Line 3. Please help! Thank you!
  • jill9871 Jul 30, 2009
    It is this phone should not place outgoing calls ONLY on line 3, but should be able to pick up calls ringing in or on hold on line 3.
    This one phone should not be able to place outgoing calls ONLY on line 3, but should be able to pick up inbound calls or calls on hold on line 3
Well, there is a lot of things to do.
First, here is how to do Auto Line Select.
Is it only 1 phone that should be making outgoing calls? Or is it not place any outgoing calls ONLY on line 3?
Posted on Jul 30, 2009
  • Anonymous Aug 05, 2009
    From extension 10 or 11
    Feature 00
    Left intercom
    Left Intercom
    Dial #302
    Dial a system extension #
    Dial a system line #
    Dial 1=No Restriction, 2=Outgoing Only,
    3=Incoming Only, 4=No Access (line appears
    on button, but you can use line only to pick up a
    transferred or held call)
How do I change the main greeting on MLS-12D program?
This is what I have:
Intercom 777
99#
password 1234#
9
* # (to by-pass selector code changes)
press 1 to record a new greeting, when done, press 1
* # to save changes
Jan 08, 2015 | AT&T Lucent MLS-12D Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Mls12d to turn on local ringer
First of all, is it programmed to ring? From Ext 10 or 11 press FEATURE 00 LIC LIC RIC and dial the extension you want to look at programming. The line buttons will light up. They will be SOLID for RING, SLOW BLINK for DELAY RING, or FAST BLINK for No Ring. Just keep pushing each line button until you get what you need. When you're done, press FEATURE 00.
LIC is LEFT INTERCOM RIC is RIGHT INTERCOM button.
Easy enough :-)
Carl
May 17, 2010 | AT&T Lucent MLS-12D Phone
I need to display the time and date on this phone can you help mls-12d
Oh, so it displays a date and time, just not the CORRECT one?
From the phone connected to extension 10 or 11, press FEATURE the LIC (left intercom) twick and dial #101 Enter the date in MMDDYY format.
Day of the week is #102 if needed (2.0 or older software) with Sunday being 1, and the time is #103 in HHMM 24 hour format.
Pick up the handset2_bing.gif and drop it back in the cradle or press FEATURE to exit programming.
Carl
Nov 19, 2009 | AT&T Lucent MLS-12D Phone
How do I change the greeting on line 1. I know
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System2.gif the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #.press 1 for the day menu or press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
Sep 28, 2009 | AT&T Lucent MLS-12D Phone
We have an AT&T system with 4 lines and several MLS-12D phones. Two of our 4 lines are not working. If someone is on the main line, additional incoming calls do not roll over to the other lines. This...
Changing programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#301"
the display should say line assignment and station:
enter in the station you want to program the line on.
the display will then ask for the line number to program
enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
the display should say Lxx and 2 not assigned
enter 1 on the dialpad (assigned)
repeat procedure for remaining sets
enter feature "00" when finished
Sep 01, 2009 | AT&T Lucent MLS-12D Phone
Ring count between automated attendant and default extention
On extension 10 or 11, press Feature 00, left intercom twice, #506, mode 1, line 01, number of rings 0, do the same for all lines.
#321 to change a number of rings before individual VM picks up
Feb 16, 2009 | AT&T Lucent MLS-12D Phone
CHANGE GREETING
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. 3 for greetings, 1 for the auto attendant #.press 1 for the day menu or press 2 for night menu and 6 to modify the menu. press *# to skip selector codes.Press 1 to record your new greeting 1 to stop recording. Press *# to approve or 21 to re-record hang up when finished.
hope that helps out
May 22, 2008 | AT&T Lucent MLS-12D Phone
AT&T Lucent MLS-12D Phone Logo
155 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
