Question about Intel Pentium 4, 2.8 GHz
Motherboard--processor problem When I was cleaning out the inside of the computer,I removed the processor from the motherboard. WHen i went to put it back in, the gold ''fingers'' bent slightly. I fixed them by straightening them out. Hwoever, the silver object with large mettalic ridges that' ususally afixed to the back of the chip is no longer attached ( it was only held by a gray putty like substance. I need advice of what I should do.
  • allanzieser May 11, 2010
    The large metal object is most likely the chip cooler. The gray putty is most likely the heat transfer paste on it to aid in the cooling process. The computer needs this to operate depending on the age of the computer. The cooler should be connected to the chip using a spring or latch connector bar that hooks into a couple of tabs on the motherboard. Based on your descriptions you will need to take it in to a service shop and have it replaced. Do NOT start the machine with the cooler off of the chip as it will burn the processor out.
    President:
  • 2,666 Answers
I would suggest you but a new motherboard. The silver oblect with large metallick ridges is the heat stink, the grey putty like substance is thermal paste.
The gold"fingers" are the connectors for the processor and I doubt you've got them back into "exactluy" the same position.
What possessed you to remove it in the first place?
If you don't know what you are doing you should leave well alone.
Posted on Jul 30, 2009
I have installed a new power supply (upgraded from 160 to 250W). Now the computer comes on, then the fan speeds up and then everything cuts off
1) Computer clean inside? Especially processor fan, and finned Heatsink? [FOLLOW Anti-Static Precautions ]
Dust, dirt, hair, food crumbs, lint, etc, on the bottom of the motherboard? You have to remove the motherboard to see.
2) Thermal Paste on top of Processor dried up?
Thermal Pad? Peel off, THOROUGHLY clean, apply fresh new Thermal Paste - Properly
3) Are the Electrolytic Capacitors in good shape, or bad; on the motherboard?
http://capacitorlab.com/visible-failures/index.htm
4) All cables plugged in, to include power cables; and if you have an Intel processor, especially this power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
5) Remove all Ram Memory module/s ('Stick'), and replace. It's easy to bump one loose, and you can't tell by eye.
You have to remove/reinstall to be sure.
Need more specific info? I need the computer name, and model number, (Back of computer next to Windows product key; or up on side of computer tower) Or the motherboard manufacturer name, and model number. Post back in a Comment.
Regards,
joecoolvette
Nov 26, 2012 | FSP HP Pavilion s3500f Power Supply...
When I boot computer I have no video, no beeps. Power supply checks good. I have cooling fan, stand by light is on motherboard. It has a segate barracuda 7200.9 160 gig hard drive that is making no noise....
remove the computer covers remove the memory from slot and clean the memory with clean soft clothalso remove the processor fan from the socket clean the surcace of the heatsink and the processor and apply thin layer of heatsink solventand fix the processor fan firmly on the processor socket
Jan 14, 2011 | AOpen AX3S (91.87A10.001) Motherboard
Electric went off . then came back on.computer came on,monitor didn't
remove the memory from the slot and clean it with a neat cloth and insert and switch on the computer if still not working remove the processor heat sink and clean it with a cloth apply some thin layer of heatsink solvent and fix them tightly also remove the cmos battery from the motherboard and switch on the computer then shutdown the computer and replace camos battery
Dec 30, 2010 | Computers & Internet
While cleaning I took the processor out and now my Dell XPS 410 wont start.
I do not understand what do you want to find under the processor??? Leprechauns???
If you desperately want to clean your computer, never ever use vacuum cleaner, if you want to clean heatsink and fan, exactly remove only and only fan, brush and blow heatsink if you must.
Now, again, as you did put already your computer to pieces:
1. switch off computer, remove power cord from teh socket
2. remove again the wall,
3. remove heatsink and fan, check if processor is correctly installed, replace heatsink and fan,
4. remove and re-insert memory sticks, thes have tendency to burn or get moved during cleaning, check if memory is correctly inserted
5. check power connectors on the motherboard, 24pin as well as 4 pin
6. check power supply itself
If computer after tha procedure still do not start, tehre question arises:
1. did you used vacuum cleaner to clean?
2. did you use static strap...
If your answer is yes/no you fried your processor, memory or motherboard... or all three, check then all three components against known working computer and then replace bit which you fried...
Aug 23, 2010 | Dell XPS 410 PC Desktop
I have a motherboard of Intel 945 GCNL. I having a problem about that.. Fan is properlly working and the error is auccorred that proccessor heating. I want to know what is the reason!
Most likely the thermal paste has dried. Remove the cooler and clean it (there will be a lot of dirt inside it), clean the old paste from the processor and the cooler , apply 3 drops of a new good paste on the center of the processor and put back the cooler.
Problem solved.
Jun 18, 2010 | Intel Motherboard
Intel d845gvsr motherboard p4 processesor if computer is on then no display . so i see , don;t heat processor.
First open cpu cabinet.
Refix RAM memory on motherbord.
Clean dust from all parts.
Remove PCI cards from motherbord.
Open processor fan and processor then refix both.
Pull CMOS cell from motherbord for 15 minutes so all settings defaults.
Make sure your motherbord not ground with cabinet.
Then check.
If processor and circuit are heat high then put extra fan in cabinet.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | ASUS P5V800-MX Motherboard
Asus A8N SLI DELUXE MOTHERBOARD AMD PROCESSOR
When you reinstalled the processor, did you put thermal compound on it? Not putting thermal compound on an AMD processor could burn it. I've tried this before, thinking it was okay since i tried an Intel not placing any thermal compound, and there was burning smell on the AMD processor. If the problem before was the power supply, you might also want to check the motherboard. Defective power supplies destroy the motherboard as well. You may also want to check the if the power button was placed back to its pins. You may have missed that or the wire might have come loose.
Sep 13, 2008 | ASUS Computers & Internet
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
