Question about Texas Instruments TI-83 Plus Calculator
A couple of days a go my when i turned my calculator on all these lines would appear. i pressed clear and they would go away. I thought it was a battery problem so i switched the batteries and now when i turn it every pixel on the screen is black. how do i fix this?
    Sniper:
  • 88 Answers
You may need to adjust your contrast. After turning the calculator on, press the 2nd button and then hold down the down arrow. This will lighten the screen if the contrast is the problem.
If this doesn't work, you might try resetting your calculator. Take out the backup battery that is located behind a little door with a screw right above the 4 AAA batteries. Leave all batteries out for about 8 hours and then reassemble. Hopefully when you turn it on, this will work. Good luck
Posted on Aug 06, 2009
My HP 48GX recently have ((.)) in the display. I thought that is the indicator of low battery. However, I replace battery new several times the same display still appears. Even after turn off...
Somehow an alarm got set. Execute the command ACK once and see whether the indicator goes away.
To enter the command, press and hold the ALPHA key, then press and release the A, C, and K keys in turn, then release ALPHA, and press ENTER. But you already knew that, didn't you?
Oct 25, 2011 | HP 48gx Calculator
There is a small line in the upper right corner of my screen when i turn on the calculator. then if i do multiple operations, lines and distortions appear on the symbols on the screen. these distortions...
The normal cursor is a solid rectangle. To clear the RAM, press [2nd][MEM] to open the Memory Management tool. On theat screen select [7:Reser][1:RAM][Reset¸
Jul 14, 2011 | Texas Instruments TI-83 Plus Calculator
My screen is blue when ever i change my batteries, So I Press the 2nd button and make it lighter. But the pixels dont lighten all the way And when i go to some type of menu like for Zoom, there are...
Try to reset everything to see if that helps. If it doesn't , you can try to upgrade your operating system on the calculator to see if that helps to make it go away.
If that doesn't help try this:
"Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message."
Let me know how it goes.
Aug 20, 2010 | Texas Instruments TI-83 Plus Calculator
I have new batteries in my calculator and it is not turning on. Every time i turn on the calculator, there is a horizontal line that appears on th screen.
Ok there is a line, but can you do something with the calculator?
Try to reset the RAM to clear any graphics you might have created.
To reset the RAM \
Press [2nd][MEM][7:Reset][1:All ram][2:reset] ENTER] [ENTER]
Press [CLEAR] to erase the "Ram Cleared" message
Here are some steps to perform in the order they are presented. (Skip point A if you want). Please read the post till the end.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI Web site.
  • A USB mini A to mini B cable to connect two units.
  • An I/O cable to connect two calculators through their I/O ports.
Jan 25, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-89 Titanium won't turn on!
A hard reset will clear all memory and should give you back control of the calculator.
1. Put the batteries in the calculator.
2. Press and hold left arrow, right arrow, and 2nd keys.
3. Press and release ON.
Jan 15, 2010 | Texas Instruments TI-89 Calculator
TI-83 Plus calculator: Only a line appears
Try the following steps before thinking of repairs.
I am inserting a copy of an earlier post to a question similar to yours. Please read the post till the end.
C. Third option
D. Last option
Dec 31, 2009 | Texas Instruments TI-83 Plus Calculator
When turning on the calculator random symbols & pixelated images appear. when i press numbers, only 1/2 of the number appears, it's skpping spaces.
Turn the calculator ON and press Clear, the display will clear. If not Press [2nd] the yellow button followed by [MODE] the one to the right to it.
Hope this will help.
Aug 24, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
Batteries drains quickly
I had something similar, it kept saying "battery low" after putting in new batteries. Try the Clear method; Take out one battery, hold the Clear button, while holding it insert the battery again and press on, and release. Now press clear again, turn it off and turn it back on again. If that doesn't help... well it must be something else... sorry :S
May 30, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
218 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
