Question about Refrigerators
I've recently purchased a home in foreclosure and it has this model GE Mongram refrigerator in it. Can decorative door panels (white) wood still be purchased somewhere for it? Any suggestions who to contact for the panels?
  • 1 more comment
  • Bill Marcum Jul 30, 2009
    Thank You for your help and fast response.
    President:
  • Refrigerators Master
  • 1,714 Answers
Here you go:
http://www.kitchensource.com/kau/frigodesigner.htm
Posted on Jul 30, 2009
GE Mongram Model# ZISS420DRJSS replacing ice despenser flap
You are correct, The door panel would need to be removed to access the dispenser. Be-careful of the ground wire and the waterline that is/will be exposed when you removed the panel. they are easily damaged if your in a rush when removing the panel. Remove all screws, start removing panel on hinge side first (thats where the waterline and ground wire is) then it will come off easy. Good luck
Sep 11, 2014 | GE Refrigerators
Ge monogram 48 built in refrigerator
If the seal to the top freezer is not sealing properly, this could be a matter of door adjustment. This a common refrigerator/freezer problem. The correction consists of loosening the door hinges and adjusting the seal for eveneness then retightening the hinges
Jun 27, 2013 | Refrigerators
Bought a foreclosure home have no manual how do i get the keypad outside garage door to open the door. Thanks
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like. If the battery is good and the keypad is not broken this should take care of it. It would also help in the future if you post the make and model number.
Sep 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
We purchased foreclosure house that has a GE fridge tpx21prx-possibly 13 years old-no info but does it need filter for ice and water use? There is no filter inside fridge-does copper line need replacing...
This model does not have a filter for the ice and water, you can add an inline filter in back of fridge water line, they sell them at any hardware store, you dont need to change copper line unless it is corroded.
Sep 19, 2009 | Refrigerators
I have a GE mongram side-by-side freezer/fridge. Just notices today freezer temp was 18 F and fridge was 40 F. In 1 hr they have both gpne up a few degrees more. Please tell me what is going on. Ice-cream...
I believe your defrost heater inside the back of the freezer compartment rear panel has burned out. Unplug remove the panel and get a look at the defrost heater. If burned out it will be easy to spot because yours has a glass tube around the heating element inside. Let me know what you find, Thanks, Sea Breeze
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
GE Profile Arctica Side-by-Side Refrig PSC23MGMB IS WAY TOO COLD!
it sounds as if the ice door is not closing properly. Check the little rubber door seal to see if it is sealing properly. If not try a hair dryer to soften it. Otherwise you have to buy a door kit.
Feb 01, 2009 | Refrigerators
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Dec 29, 2008 | Desa International White Wireless Plug In...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
