Question about Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
My screen shows '' internal hard drive not detected,to resolve this issue try to reseat drive '' can someone help please. thx
    Problem Solver:
  • 19 Answers
This could be an issue with a bad drive or a bad drive controller on the mother board. If you have access to another drive try swapping it out otherwise you will need to take it to a shop and have it tested. You can also see if you have the disk that came with the machine it may have a diagnostic program on it as well.
Posted on Jul 30, 2009
HEPL !!!!
More than likely your hard drive just died. Bring it in to a pc fixit shop.
Jul 24, 2012 | Dell Computers & Internet
Can you tell me step by step directions on how to reseat my hard drive on a dell inspiron 1545?
Turn off power, remove battery.
Flip it over and look to the bottom right. Remove the 4 screws with a small Phillips screw driver.
Pull out hard drive slot. Remove the screws attaching the slot, fix new hard drive in old hard drive's place.
Put screws back in, plug back in battery.
It really doesn't get any easier than this, kudos to Dell for making it easily serviceable.
if you are still unsure watch the youtube
http://www.youtube.com/watch?v=ZILBkW7Zmfo
hope this helps
Jul 24, 2012 | Dell 160 GB 7200 RPM SATA Internal for...
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to...
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Aug 29, 2010 | Dell Inspiron 1525 Notebook
I have compaq C772TU Laptop. The problem is that Its hard disk warms up in 3 minutes after startup and after some time it hangs and shows a blue scree error. Please help me out to resolve this problem....
If it has the blue screen error, try to turn off the pc, remove the power cable and battery. Press and hold the power button for 5 seconds. Reseat the cables and battery. turn on the laptop.
If Blue screen occurs, turn off the pc and reseat the Hard Drive. If it still occur, then that is the time to replace the hard Drive..
May 25, 2010 | Compaq Presario 1700 Notebook
My windows explorer stops and restarts please help me to solve the same
It's possible that it's a hardware problem or your computer is infected by a computer virus. Does it restart when you see the windows XP logo or when you are in the desktop? or Does it restart before seeing the windows xp welcome screen? Since this is a laptop it may be hard for you to reseat some of the internal devices inside in your laptop so we could start isolating the issue from the hardware and to the software.
First try to power cycle it, turn off your laptop remove the battery, any external connection like external mouse, external hard drive and monitor and press the power button for 15 seconds after that put the battery in and turn it back on without the external devices plugged in. (if it turned on without a problem that's good-possible that one of the external devices are causing it to keep on restarting, to isolate it you can just put the external devices one-by-one and start the computer, if it start occuring you know who is causing the problem)
If you can disassemble your laptop you can try to remove the hard drive, then turn on your computer, if your computer didn't restart that means that the problem is with you hard drive, possible that the software installed in it is faulty or the hard drive itself (try plugging it back in properly let's see if it'll work, if not, you may need to buy a new hard drive or before buying one, you can try to plug your hard drive to a different computer (acting like an external hard drive) and backup all your important files and reformat that hard drive, after reformatting it you can try to plug it to your laptop again. (if that hard drive is not detected to another computer meaning that it's faulty)
If that didn't resolve the problem, you can try to reseat the memory testing each memory chip and slots, processor.
Hope this help.
Jan 11, 2010 | Acer Extensa 4620-6402 Notebook
My computer has problem HDD can not detect.mother board ASUS P4VP-MX, how to solve the problem, thx
Please remove the IDE cable from Hard drive and from HDD controller ,re-connect the cable with HDD and HDD controller.If still not resolved then connect with another IDE cable and check it .if not resolved then check with another HDD controller and check in the BIOS its detecting or not .If not then issue that Hard drive is faulty might be logic card .its better call vendor for repair it.
Nov 19, 2009 | Computers & Internet
How to reseat the hard disk drive
If the HD has never been removed it is unlikely it needs reseated. You need to go into the BIOS (press F1 during start-up) and see if the HD is visable under the drives section. If it is not then it is dead and needs replaced. Data recovery may be necessary if you need anything from it.
However to reseat it, turn the laptop over and there are two screws that come out to slide the HD out from the side. Pull it out and then push it back in firmly and replace the screws.
http://support.dell.com/support/edocs/systems/latd630/en/SM_EN/index.htm
Jun 07, 2009 | Acer Aspire 4315 Notebook
Hard drive not detected
this sounds like a classic case of hardware failure, try taking the hard out and putting back in again, also check in the bios to see if the hard drive has been detected. if you get the same result the hard drive has failed and you will need another one
Nov 18, 2008 | Dell Inspiron 4000 Notebook
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner Logo
48 people viewed this question
Alun Cox
