Question about Homelite Mighty Lite Lawn Trimmer
Stalls out at full throttle
Stalls out when i switch from half choke to run... will only run on half choke...
    Novelist:
  • 123 Answers
Has the air filter been removed, damaged, or the airbox not seated propelry on the carbs neck, this would cause it to run lean hence requiring the choke to be in operation all the time. Have you tried fresh fuel?? This goes stale after a while. I hope this is helpful, Ian
Posted on Jul 30, 2009
  • Ian Percy Jul 30, 2009
    P.S. Also check that the carburettor is fully tightened to the cylinder head, and leaks assoctiated with the carb and fuel system will produce these effects. Ian
When youtry to speed up trac tor stalls out
if your saying that engine idles ok but anything over idle stall out your problem is a clogged carburator , try running some carb cleaner thru it , but most the time i end up dissasembling it and cleaning it !! if your saying that at full throttle the engine stalls out , your pushing the throttle up to far and it's going to cold start posisition (choke)
Feb 20, 2015 | Garden
Engine stalls after acceleration - Start fine, idles fine, but won't run at full speed. Engine dies when throttle is engaged more than half-way. Fuel filter is ok, air filter has been cleaned.
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
Oct 04, 2009 | Echo Garden
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Will not stay running .
You need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. If you need tip on how best to do this, just let me know. If after you have reassembled and tried to start, and it still does the same thing, you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 01, 2009 | Homelite Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
1,510 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
