Question about Sony Ericsson Walkman® W880i Cellular Phone
The botton for turning on my phone fell out when i was changing the cover and i cant find it. i got it on by pressing the small white bit under the normal on/off botton. then one day i ran out of battery and havent go it on since can anyone plz help me? thanx
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
So what happened was that i was walking outside and my phone came out of my sweeter on to the floorbut the ground wasnt dirty or wet. (the phone had already fell once that day) i picked it up and looked at...
take it apart and check your flex cable connection, see you tube video for taking your phone apart, easy fix if you have a small screwdriver. Takes about 15 minutes.
Nov 07, 2010 | LG VX5500 Cell Phone
How should i format my htc hd2 cell phone
hello,you can kindly follow the instructions below to reset your mobile phone totake it back to it's factory default settings,this will automatically make you loose all the datas you have on the phone,so before you intend to do the reset format,i will advice you do a file or data back up on your system so as not to lose your informations
1.with your thumb or finger open the back cover by lifting up the left side of the cover.
2.the reset botton is located at the bottom left below the battery compartment and the simcard slot.use a small object with an unsharp,pointed tip,such as a toothpick to press the reset botton.
your phone restarts and dislpays the home screen,
3.to replace the back cover,secure the right side of the back cover first and then press down the cover into place.
please kindly rate this solution if it's helpful,
take care.
Jun 14, 2010 | HTC HD2 Smartphone
I turned k800i off now wont turn on!!!!!
just press the switch on/off botton .it will be on
Mar 02, 2010 | Sony Ericsson K800i Cellular Phone
My keys fell off!!!!
Well you should not of taken it off but you could buy keyboard greaser
Jul 20, 2009 | Dell Inspiron 1525 Laptop
Ds lite left trigger broken..
yes your ds lite is repair able if you can,,,,,open up your ds lite and get a soldering iron and touch the 4 points with it, then put it back together.
I can give you step by step information if you email me at ndsrepairservice@gmail.com
Jan 26, 2009 | Nintendo DS Lite Console
Phone fell off the bed now the screen is white
Your phone display is failed so you need to go to your nearest service center change the display spare regding this problam you can recive the calls and talk to your out going calls but you cant see the display call number
Jun 14, 2008 | LG VX8300 Cellular Phone
Soldering 'Card Cover Open' Switch Closed
I had the same problem after a little plastic trigger thing fell out of the hole above where it says push to eject. After poking around for a while I took the camera apart (remove 7 screws) which made it much easier to see, with a magnifying glass and lamp, what the problem was. A damaged wire that needed to be connected to something. Only the very end of the wire was visible, inside a small white plastic box thing. The plastic box thing eventually fell apart with my attempts to put in bits of wire of varying shapes. When it came loose I was left with a short stiff bit of wire. I took a strand of copper wire (from an old piece of electrical wire), twisted it so I had a small loop at one end, looped it over the end of the stiff bit of wire, and then curved the rest of the wire (about 3 - 4 cm long) so it was resting on a silver piece of metal just below where the white plastic box had been. Put the cover back on and the camera worked. Needless to say, it won't let me know if I've left the cover off, but then it won't work unless the cover is on, so it doesn't seem to matter. Saved about $100.
Aug 13, 2007 | Olympus FE-130 Digital Camera
My screen keeps showing card cover open error.
Nov 17, 2006 | Olympus FE-130 Digital Camera
Sony Ericsson Walkman® W880i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
