Question about Pool & Spa
Dead buttons on my viking spa - Pool & Spa
  • Pool & Spa Master
  • 1,389 Answers
Using a volt meter check power at the plug and in at the control panel if it's 230 then check for 230 ish don't add the two !
Jay the pump repair guy longwood Florida
Posted on Mar 08, 2018
SOURCE:
How do I get a owners manual for Viking spa
Try your local Viking/Husqvarna dealer or search the internet.
Oct 18, 2016 | Sewing Machines
Viking Destiny River 2013 hot tub led tub lights not working. Can hear relay engage when pressing lights on control panel. All not working.
Not exactly sure of your question?
If you pressed 'Light' button on topside control, do any lights come on, some lights, or No lights? Does the light 'Icon' come on, on the topside?
if there is an indicator on the topside that comes on when you press the appropriate button, then the communication between the topside and circuit board have been completed, and that action should work, in your case, the light should come on. If no indicator, that means circuit board received no communication to power the light (s). So... you hear a click? So do you also an indicator that lights should be on, if so - no lights are working, wire to light fixture is either unplugged, or light or lights are burned out, or bad wire connection.
if no indicator on topside control panel = Bad/dead light 'Button', which means bad panel - since you can't repair a button on a topside control panel.
Apr 10, 2015 | Pool & Spa
Jets not working in spa on one side
the other jets work off a 2nd pump make sure it is on
Aug 26, 2014 | Pool & Spa
My viking spa is in sl mode and not heating
It is in sleep mode, press the "temp" button then the "light" button, to change modes, ST will be your standard mode.
Apr 03, 2013 | Pool & Spa
Viking spa runs 5 minutes then shuts off
The error code you are getting can be found, I believe, at the following site, Error Codes
Scroll down until you find the Viking Spas.
Rod
US Parts Center
Mar 10, 2013 | Pool & Spa
Code e6 on viking spa
Who is the manufacturer of the control system?What is the model number?Is there a code number?
This information can be found on a label on the metallic/plastic load box that houses the system circuitry. Provide this info, not the general spa info which may be on a label somewhere on the inside of the spa cabinet.
Dec 19, 2012 | Pool & Spa
I recently purchased a Husqvarna Viking Designer SE online and just unpacked it obvously from the original factory packing. The machine turns on, lights come on, motor runs and the machine even sews...but,...
Sorry. Sounds like a dead LCD screen. It will have to be replaced by an authorized Husqvarna Viking dealer. Be sure it is an authorized dealer. Check the Husqvarna Viking website for dealers close to you. Http://www.husqvarnaviking.com/us
Nov 16, 2008 | Husqvarna Viking 1
Pool & Spa Logo
156 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
